Online Now [2927]:
Visitors: 2926
Today: 162585
Total: 153002282
Forums › The Car › 206 Problems › car jerks/judder when i clutch in
bisphenol-a
PostPosted: Sat Sep 10, 2011 2:43 pm Up
so im moving off at gear 1 and when i want to clutch in to move up to the 2nd gear i get this judder or jerk from the engine. its hard to describe but it makes this 'gah-ah' sound when clutching in and the car would have this jolt / jerk / judder. its only when going from 1 - 2 and it comes when i depress the clutch.
2-5 no problems. now because of this weirdness i have nightmares when the lights turn red and i have to stop. doesnt happen all the time, but significantly enough to irritate me. i believe my clutch is fairly good to go because the clutch pedal is really quite stiff and hard.
whats up with the judder? clutch not disengaging cleanly?
thanks for reading
pug150
PostPosted: Sat Sep 10, 2011 2:55 pm Up
Might be your engine mounts maybe the gear box mount? Its smooth through all the other gears because 1st to 2nd is the harshest change as the cars just getting going. If its not a mount then its the clutch hence clutch judder.
muzzy78
PostPosted: Sun Sep 11, 2011 12:51 am Up
I had a similar judder wich also caused my engine to rev more than usual..it was my coilpack that was breaking so could be that
pug150
PostPosted: Sun Sep 11, 2011 1:21 am Up
It could be alot of things! Does your gear stick feel like its moving on its own when you go to pull off?
broadblaster
PostPosted: Sun Sep 11, 2011 7:54 am Up
sounds to me like normal 180 clutch judder fault.
clutch should be nice and light not heavy, mine was the same when i got it judderd and was heavy put new LUK kit in and its as light and smooth as you could wish for now.
when i changed it the plate had loads of "meat" left on it but the thrust bearing was trying to eat its way through the pressure plate.
on a back road playing
_LiJ_
PostPosted: Sun Sep 11, 2011 8:31 am Up
could be a possible flywheel problem, i dont know if the 180 have a dual mass tho.
Stay in VTEC!
broadblaster
PostPosted: Sun Sep 11, 2011 8:36 am Up
no they don't mate.
