Posted: Sat Sep 10, 2011 1:12 am |
Took the clocks out of my gti to fix my rev counter and while opening them up the ribbon from the mileage display came away. How does this attach to the circuit board?
Posted: Sat Sep 10, 2011 2:58 am |
oh no...
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
Posted: Sat Sep 10, 2011 6:55 am |
Trade Rating: +45
By the sounds of tht reply it means new clocks
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK | |
Posted: Sat Sep 10, 2011 1:46 pm |
Has anyone got a set, gt or gti clocks. Also can the milage be set so its right?
Posted: Sat Sep 10, 2011 3:54 pm |
Multiplex or Pre-plex?
Posted: Sun Sep 11, 2011 1:07 am |
Multiplex I think, got 2 plugs.
Posted: Sun Sep 11, 2011 4:43 am |
Another set of clocks is no good. Im unable to get the mileage corrected. All I have to do to mine is re-attach the ribbon that goes from the screen to the circuit board.
Posted: Sun Sep 11, 2011 6:48 am |
Why can you not swap the clocks?
Posted: Sun Sep 11, 2011 7:34 am |
Dont really want to spend £40 on another set of clocks and the cost to get the milage corrected. I only need to refix the ribbon but not sure how its fixed, glued or soldered?
Posted: Sun Sep 11, 2011 8:07 am |
Well what ever way it was connected you should solder it back on! Just make sure its all wired up correctly
Cant imagine it will be easy!! Hence hwy most people usually just buy a set of new clocks if they break it!
If you get a set of clocks with lower mileage than your own they will automatically rise to your mileage
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
Posted: Sun Sep 11, 2011 8:11 am |
rick-gti wrote: |
Dont really want to spend £40 on another set of clocks and the cost to get the milage corrected. I only need to refix the ribbon but not sure how its fixed, glued or soldered? |
If it is multiplexed you won't have to get the clocks changed, they are stored in the BSI and will change accordingly
A search would have helped you discover that
Posted: Sun Sep 11, 2011 8:38 am |
tomd0801754 wrote: |
rick-gti wrote: |
A search would have helped you discover that |
ONLY if the mileage on the replacement clocks is LOWER
Posted: Sun Sep 11, 2011 8:44 am |
MrBSI wrote: |
rick-gti wrote: |
ONLY if the mileage on the replacement clocks is LOWER |
I never said anything in detail I ain't doing ALL the work.
Posted: Mon Sep 12, 2011 6:22 am |
ive got a spare set of clocks so going to try and make 1 good out of the pair, and am keeping my eye open for another set with 80000 miles or less. most ive found have been higher.
