Latest: heikkisj
Overall: 17126
Online Now [51]:
Visitors: 50
Today: 10562
Total: 100189213
Forums › The Car › 206 Problems › Newbie with mpg problem
steve-1965
PostPosted: Mon Sep 12, 2011 4:42 am Up
Hi all, new to the forum and have a problem with fuel economy. I bought the car last week, it is a 2003 1.1. I use the car on 13 mile trips to work, half dual carriageway and half normal roads. Putting a tenner in I'm getting approx 30 to the gallon. Air filter was dirty so changed it, any ideas,
Thanks, Steve
PostPosted: Mon Sep 12, 2011 4:44 am Up
You have a heavy right foot.... simples Cool
PostPosted: Mon Sep 12, 2011 4:46 am Up
Just try giving it a full service and running it on high octane premium fuel for a month and see if it improves Smile
Hotchy
PostPosted: Mon Sep 12, 2011 5:59 am Up
I got about 30mpg in my first 1.1 i had. I red lined every single road though... warm or cold Laughing not 1 engine problem to be had in over 70k either, solid we guy so he was Laughing
2.0hdi sport + DAC 2005, aegean blue! Very Happy
Abzynthe
PostPosted: Mon Sep 12, 2011 6:09 am Up
East Area Rep - Abzynthe
My mrs only gets that and she has a very well maintained car. Shes not a mad driver either. Its mostly town driving.
So I would say thats about right really.
Just get a bigger engine Razz My 1.6 can do 520 miles on a tank, pure motorway driving Wink
PostPosted: Mon Sep 12, 2011 6:16 am Up
Drive like a tree hugging coffin dodger & it might improve.
PostPosted: Mon Sep 12, 2011 6:20 am Up
Warning may result in death due to serious boredom .
PostPosted: Mon Sep 12, 2011 7:43 am Up
Thanks, Steve
there's nothing wrong with it, 1.1 is gutless & its trying to lug nearly a ton of 206 along.
Deckchair5
PostPosted: Tue Sep 13, 2011 1:31 am Up
With a 1.1 engine it should be easy to obtain 40mpg average and 50mpg or more on a long run
click here for figures of over 1000 1.1 owners<<<
Once you have checked the normal service items, (especially now you cleaned the air filter) then it's best to reset the ECU so it relearns quicker the best set up for the current state. It'll get there in the end but it's a good idea to tell it to "take a fresh look" whenever you change any major engine part that affects economy. That will reset your LTFT (long term fuel trim) and it will find the new best settings
LAMBDA
After that, the most significant effects on fuel economy (besides your right foot) are the lambda sensor - which will fine tune back the fuel used when at steady rpm -so that has a huge effect on economy
MAP
and your MAP sensor which tells the ECU how much air is going in so it adjusts fuel accordingly.
Either one of those giving misinformation and the mpg plummets
steve-1965
PostPosted: Tue Sep 13, 2011 4:50 am Up
Thanks for the replies, after looking at the mpg figures, mine seems quite low, how do I reset the ecu? Is it just a matter of disconnecting the battery?
PostPosted: Tue Sep 13, 2011 5:01 am Up
I would say your getting about the right sort of MPG with the driving your doing to be honest. Your only doing short journeys so the engine will only just be getting up to temp when you come to your work place and the same on the way home.
The MPG figure shown are done under lab conditions and dont really reflect on the true world.
When was the last time you gave it a good service? Give it a good service and see if that improves things.
Deckchair5
PostPosted: Tue Sep 13, 2011 5:15 am Up
No, those are real owners figures and it's an average consumption ie for varied driving conditions. The manufacturer's figures seem to be done downhill with a wind behind you Very Happy
Yes that'll do it if you disconnect for an hour or so
Mattie-RS
PostPosted: Tue Sep 13, 2011 6:46 am Up
Obv this guy knows more than us Rolling Eyes
PostPosted: Tue Sep 13, 2011 8:04 am Up
Exactly Wink
TU1 lump pulling nearly a ton of weight along, you aint gonna get good mpg figures from it unless driven like a eco hippy Laughing
