Posted: Mon Sep 12, 2011 11:36 am |
one of my manifolds bolts have snaped(where joins to down pipe) the spring bits have gone. i have manage to bolt tight but down pipe still rocks side to side abit. it also blown to.
can i buy new bolts to put in or can i get away with filling it with gum gum paste?
please can someone help
Posted: Mon Sep 12, 2011 11:53 am |
Just go spend £12 at any Peugeot / Citroen dealer for the downpipe fitting kit.
Posted: Mon Sep 12, 2011 11:57 am |
MrBSI wrote: |
Just go spend £12 at any Peugeot / Citroen dealer for the downpipe fitting kit. |
how easy is it to get bolts of from manifold?
Posted: Mon Sep 12, 2011 1:37 pm |
Messy ass job would need to get a drill in to hole it and get a easy out in to it. probably end up snapping the other studs aswell.
Posted: Mon Sep 12, 2011 1:39 pm |
20619d wrote: |
MrBSI wrote: |
how easy is it to get bolts of from manifold? |
Push it up through the hole.
The Peugeot / Citroen fitting kit has all the new bolts, washers, nuts, springs you need.
Posted: Mon Sep 12, 2011 1:45 pm |
MrBSI wrote: |
20619d wrote: |
MrBSI wrote: |
The Peugeot / Citroen fitting kit has all the new bolts, washers, nuts, springs you need. |
it the bit in the manifold that stuck. it snapped by the spring hence why spring fall off. will it just undo or is it welded in?
Posted: Mon Sep 12, 2011 1:46 pm |
20619d wrote: |
MrBSI wrote: |
20619d wrote: |
MrBSI wrote: |
it the bit in the manifold that stuck. it snapped by the spring hence why spring fall off. will it just undo or is it welded in? |
Its just a bolt, it will be rusted in.
Posted: Mon Sep 12, 2011 1:48 pm |
MrBSI wrote: |
20619d wrote: |
MrBSI wrote: |
20619d wrote: |
MrBSI wrote: |
Its just a bolt, it will be rusted in. |
so cut down and drill out?
Posted: Mon Sep 12, 2011 2:14 pm |
drill and stud extractor it out Pain in the ass to get at with a drill.
Posted: Mon Sep 12, 2011 2:16 pm |
20619d wrote: |
MrBSI wrote: |
20619d wrote: |
MrBSI wrote: |
20619d wrote: |
MrBSI wrote: |
so cut down and drill out? |
Knock it out they fit in from the top of the manifold
Go buy the fixing kit first to see what your dealing with.
Posted: Mon Sep 12, 2011 2:18 pm |
f*****g car may fill it with paste and use some time of clamp on it
Posted: Mon Sep 12, 2011 2:20 pm |
20619d wrote: |
f*****g car may fill it with paste and use some time of clamp on it |
Just take it to a fast fit place then, they will have fixed thousands of these over the years, Peugeot / Citroen has been using this set up for 25+ years that I know of.
Posted: Mon Sep 12, 2011 2:21 pm |
MrBSI wrote: |
20619d wrote: |
MrBSI wrote: |
20619d wrote: |
MrBSI wrote: |
20619d wrote: |
MrBSI wrote: |
Go buy the fixing kit first to see what your dealing with. |
is there no way i can just knock out and put bolt and nut on it for now untill get paid?
Posted: Mon Sep 12, 2011 2:22 pm |
MrBSI wrote: |
20619d wrote: |
Just take it to a fast fit place then, they will have fixed thousands of these over the years, Peugeot / Citroen has been using this set up for 25+ years that I know of. |
just tryin for quick fix untill get paid
Posted: Mon Sep 12, 2011 2:29 pm |
knock out if its the splined fit stud. Relatively easy compared to a threaded stud. once its out just put a bolt through til you can get the correct fittings.
