Latest: Andyblue64
Overall: 17123
Online Now [57]:
Visitors: 56
Today: 14039
Total: 98285670
Forums › The Car › 206 Talk › Side repeater glued onto my car
kurosagi01
PostPosted: Wed Sep 14, 2011 10:42 am Up
Hey guys,i bought some black side repeaters and i tried removing my clear side repeaters.
What would you suggest to do to remove my side repeater?? Mine are glued on so i can't really just yank it off.
Is there an actual correct procedure to remove them.
Advice needed. Smile
Antknee
PostPosted: Wed Sep 14, 2011 10:44 am Up
Hairdryer maybe?
Glued in? LOL!
PostPosted: Wed Sep 14, 2011 10:49 am Up
Its unusual for them to be glued in Confused
As above, just heat and prise...
Andrew
PostPosted: Wed Sep 14, 2011 10:52 am Up
Halfords has a can of spray on sticky stuff remover gel, in a slim yellow can for £6, try that
My 206 thread
www.detailedbyandrew.com
PostPosted: Wed Sep 14, 2011 11:16 am Up
Like said hairdryer and be be careful not to burn the paint, no easy way really
Seb
PostPosted: Wed Sep 14, 2011 11:17 am Up
Staff - Seb
If it's quite literally glued right in, just get something angry and cut it off Razz
PostPosted: Wed Sep 14, 2011 11:53 am Up
You sure its glued in Neutral ? If it is i would consider removing the whole wing so you can carefully remove it without doing to much damage to the paint.
craigy00craig
PostPosted: Wed Sep 14, 2011 12:21 pm Up
Are you sure its glued on? I dont understand why it would be.... only thing i can suggest is what jordan said and remove the wing to check whats goinf on
Progress Threads:
kurosagi01
PostPosted: Wed Sep 14, 2011 4:43 pm Up
What is the normal procedure then to remove them?? Because i tried every possible way and they just won't unclip themselves and as for removing wing. I don't really want do that as i have had hard time doing it once.
Antknee
PostPosted: Wed Sep 14, 2011 5:09 pm Up
if you reach behind the wing an pinch it it should just push out :S its like a spring clip on one side
PostPosted: Thu Sep 15, 2011 1:43 am Up
Bank card FTW to unclip side repeaters Wink
kurosagi01
PostPosted: Thu Sep 15, 2011 11:07 am Up
Used a card to unclip them and it works lol,and i have noticed there is glue substances on the side repeaters.
