Posted: Wed Sep 14, 2011 10:42 am |
Hey guys,i bought some black side repeaters and i tried removing my clear side repeaters.
What would you suggest to do to remove my side repeater?? Mine are glued on so i can't really just yank it off.
Is there an actual correct procedure to remove them.
Advice needed.
Posted: Wed Sep 14, 2011 10:44 am |
Hairdryer maybe?
Glued in? LOL!
Posted: Wed Sep 14, 2011 10:49 am |
Its unusual for them to be glued in
As above, just heat and prise...
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport | |
Posted: Wed Sep 14, 2011 10:52 am |
Halfords has a can of spray on sticky stuff remover gel, in a slim yellow can for £6, try that
Posted: Wed Sep 14, 2011 11:16 am |
Like said hairdryer and be be careful not to burn the paint, no easy way really
Posted: Wed Sep 14, 2011 11:17 am |
If it's quite literally glued right in, just get something angry and cut it off
Posted: Wed Sep 14, 2011 11:53 am |
You sure its glued in ? If it is i would consider removing the whole wing so you can carefully remove it without doing to much damage to the paint.
| PM me for Valeting & Detailing services at great rates!
Detailing Guides are also available ask me for more information. | |
Posted: Wed Sep 14, 2011 12:21 pm |
Are you sure its glued on? I dont understand why it would be.... only thing i can suggest is what jordan said and remove the wing to check whats goinf on
Posted: Wed Sep 14, 2011 4:43 pm |
What is the normal procedure then to remove them?? Because i tried every possible way and they just won't unclip themselves and as for removing wing. I don't really want do that as i have had hard time doing it once.
Posted: Wed Sep 14, 2011 5:09 pm |
if you reach behind the wing an pinch it it should just push out :S its like a spring clip on one side
Posted: Thu Sep 15, 2011 1:43 am |
Bank card FTW to unclip side repeaters
Posted: Thu Sep 15, 2011 11:07 am |
Used a card to unclip them and it works lol,and i have noticed there is glue substances on the side repeaters.
