Posted: Fri Sep 16, 2011 1:14 pm |
Thanks everyone
Whilst I'm here I might as well ask. When I changed my engine oil yesterday I noticed the sump gasket had a thin lining of black oil/gunk, is that ok?
Posted: Fri Sep 16, 2011 1:16 pm |
that's the sealant i believe
Posted: Fri Sep 16, 2011 6:10 pm |
my mate had a saxo and he run it for a long time with no oil. you could shake the stick in gear like it was neutral. Like a stick in a bucket. I admit I have given my box a hard time but day-today I look after it. I like to drive smooth.
One question does changing gear quickly make much difference to wear as long as the clutch is perfectly smooth?
Posted: Sat Sep 17, 2011 4:15 am |
What normally breaks on them when too larger alloy wheels are fitted? Ive got Vortex alloys on mine and its going for a remap next month for more power, im replacing the oil this weekend but what should I be looking out for mechanically thats going to go?
Posted: Sat Sep 17, 2011 4:33 am |
synchros is the first part to worn off;
probably put more stress on the differential if bigger wheels are used.
Posted: Sat Sep 17, 2011 12:58 pm |
Lee wrote: |
They aren't weak. They are built for their purpose. It's when people fit too big of wheels, do traffic light grand prix's and don't look after them that they become weak |
| Team Impossible Possible
Posted: Sat Sep 17, 2011 1:49 pm |
Its also the same with the engine turned off and clutch down, still the same clunkiness
Posted: Sat Sep 17, 2011 1:53 pm |
Andrewxps wrote: |
Its also the same with the engine turned off and clutch down, still the same clunkiness |
is all linkage tight?
