Posted: Mon Sep 19, 2011 2:57 pm |
Never been the best with cars but had a go at removing and swapping my bumper yesterday and got really p**sed off with it, never managed to get it off as couldnt get to the bot/nut or whatever was under the wheel arch.
Whats the best way of getting to it and actually getting the bumper off?
| | ![](images/spacer.gif) |
Posted: Mon Sep 19, 2011 3:01 pm |
| Ford Focus RS in white of course ![Wink Wink](images/smiles/icon_wink.gif)
filled with all sorts of goodies | |
Posted: Mon Sep 19, 2011 3:02 pm |
Trade Rating: +32
Arch liners out.
And a hacksaw should sort the bolt out ![Wink Wink](images/smiles/icon_wink.gif)
Posted: Mon Sep 19, 2011 3:04 pm |
Dremel ftw ![Cool Cool](images/smiles/icon_cool.gif)
Posted: Mon Sep 19, 2011 3:07 pm |
Buying new nuts and bolts is a good place to start. With some copper grease.
Don't they look nice?
![](http://i38.photobucket.com/albums/e105/s1pso/SDC18129.jpg~original)
get your angryyy on and kick the s**t out of it
if you want it in one piece, undo all the bolts and replace the 2 side ones with proper bolts and big washers, i used wingnuts on mine
marc206 wrote: |
http://www.206info.co.uk/Forums/viewtopic/t=3163.html |
Went by that guide to start off with
Posted: Mon Sep 19, 2011 3:11 pm |
It's often easier to access the nuts from above with the headlights removed.
Posted: Tue Sep 20, 2011 7:52 am |
Edward wrote: |
It's often easier to access the nuts from above with the headlights removed. |
Bumper comes out easy enough with the headlamps still in place.
Small mole grips & torx bit to start the bolt under headlamp, then fingers to spin it out.
Posted: Tue Sep 20, 2011 8:55 am |
just done mine, work bottom up. use a fork on the arch liner clips, and undo all the bottom screws, arch liners done. take the headlights off and rest them on the engine i found easiest, and make sure you have summat soft underneath to catch it. if your having trouble chances are you've missed a bolt/screw, just follow the edges of the bumper and you should find the little sob.
Posted: Tue Sep 20, 2011 1:05 pm |
Dave82517 wrote: |
take the headlights off and rest them on the engine i found easiest |
Easier to not remove the headlamps as it screws up the beam alignment ![Laughing Laughing](images/smiles/icon_lol.gif)
Posted: Tue Sep 20, 2011 1:10 pm |
MrBSI wrote: |
Dave82517 wrote: |
Easier to not remove the headlamps as it screws up the beam alignment ![Laughing Laughing](images/smiles/icon_lol.gif) |
Most mot place will re-align them for free, so it's not really the end of the world
And how is it easier not to remove the headlights?
| Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre ![Very Happy Very Happy](images/smiles/icon_biggrin.gif)
TEAM: I'm a greedy jelly fiend! | |
Posted: Tue Sep 20, 2011 1:29 pm |
MrBSI wrote: |
Edward wrote: |
Unless the nut is seized on the bumper bolt.
Posted: Tue Sep 20, 2011 1:45 pm |
The nut seems to just turn and turn
Posted: Tue Sep 20, 2011 2:03 pm |
If you can, and its been undone a little
Pull the bumper towards you (to the side), that is with all the other bolts undone
It may break, mine didnt, but be warned
Then get a hack saw or molegrips
| Team Impossible Possible
