Online Now [589]:
Visitors: 589
Today: 17662
Total: 104927230
Forums › The Car › 206 Talk › Whats best way of Removing Front Bumper??
acotton21
PostPosted: Mon Sep 19, 2011 2:57 pm Up
Never been the best with cars but had a go at removing and swapping my bumper yesterday and got really p**sed off with it, never managed to get it off as couldnt get to the bot/nut or whatever was under the wheel arch.
Whats the best way of getting to it and actually getting the bumper off?
marc206
PostPosted: Mon Sep 19, 2011 3:01 pm Up
www.206info.co.uk/Foru...=3163.html
Matt
PostPosted: Mon Sep 19, 2011 3:02 pm Up
Trade Rating: +32
Arch liners out.
And a hacksaw should sort the bolt out Wink
PostPosted: Mon Sep 19, 2011 3:04 pm Up
Dremel ftw Cool
PostPosted: Mon Sep 19, 2011 3:07 pm Up
Buying new nuts and bolts is a good place to start. With some copper grease.
Don't they look nice?
Antknee
get your angryyy on and kick the s**t out of it
if you want it in one piece, undo all the bolts and replace the 2 side ones with proper bolts and big washers, i used wingnuts on mine
acotton21
marc206 wrote:
http://www.206info.co.uk/Forums/viewtopic/t=3163.html
Went by that guide to start off with
PostPosted: Mon Sep 19, 2011 3:11 pm Up
It's often easier to access the nuts from above with the headlights removed.
PostPosted: Tue Sep 20, 2011 7:52 am Up
Bumper comes out easy enough with the headlamps still in place.
Small mole grips & torx bit to start the bolt under headlamp, then fingers to spin it out.
Dave82517
PostPosted: Tue Sep 20, 2011 8:55 am Up
just done mine, work bottom up. use a fork on the arch liner clips, and undo all the bottom screws, arch liners done. take the headlights off and rest them on the engine i found easiest, and make sure you have summat soft underneath to catch it. if your having trouble chances are you've missed a bolt/screw, just follow the edges of the bumper and you should find the little sob.
That is all.
PostPosted: Tue Sep 20, 2011 1:05 pm Up
Easier to not remove the headlamps as it screws up the beam alignment Laughing
Mrs_Howey
PostPosted: Tue Sep 20, 2011 1:10 pm Up
Most mot place will re-align them for free, so it's not really the end of the world
And how is it easier not to remove the headlights?
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
PostPosted: Tue Sep 20, 2011 1:29 pm Up
Unless the nut is seized on the bumper bolt.
acotton21
PostPosted: Tue Sep 20, 2011 1:45 pm Up
The nut seems to just turn and turn
PostPosted: Tue Sep 20, 2011 2:03 pm Up
If you can, and its been undone a little
Pull the bumper towards you (to the side), that is with all the other bolts undone
It may break, mine didnt, but be warned
Then get a hack saw or molegrips
