Posted: Sat Sep 17, 2011 9:07 am |
Hi all
i am still having problems bleeding my brake 3 out of 4 bleed nipples snapped so i have drilled them out and fitted some bolts
attached the auto bleed kit and went around and undone each bolt and the fuild comes out then do it back up a couple of times on each wheel and then unattach the auto bleed kit
press the pedal and there is little pressure so pump it and you get some good pressure so start the car and then you loose ALL pressure
PLESAE HELP
| 2003 Pug 206 2.0 GTI 180
IT TAKES TALENT TO BE THIS NOOB!!!! | |
Posted: Sat Sep 17, 2011 9:11 am |
swallow your pride and pay a mechanic, save your time
Posted: Sat Sep 17, 2011 9:12 am |
i have one problem the car has no mot or tax and i have no brakes so i cant get the car any where
Posted: Sat Sep 17, 2011 9:13 am |
LilLew wrote: |
Hi all
PLESAE HELP |
You need bleed nipples not bolts.
GTI 180 needs bleeding with Peugeot Planet.
Your just wasting your time until the job is done CORRECTLY!
Posted: Sat Sep 17, 2011 9:25 am |
How can you use an auto bleed kit using bolts in place of bleed nipples?
Go and buy some new nipples from either a dealer or motor factor.
Posted: Sat Sep 17, 2011 9:26 am |
Posted: Sat Sep 17, 2011 9:32 am |
bolloxs looks like a set of new cailpers for me then
Posted: Sat Sep 17, 2011 9:40 am |
why not use buy some bleed nipple....they are only a few quid each
Posted: Sat Sep 17, 2011 10:05 am |
because the orignial had to be drilled out because it snapped the easy out tools and the whole is slightly bigger then a bleed nipple
Posted: Sat Sep 17, 2011 10:19 am |
LilLew wrote: |
because the orignial had to be drilled out because it snapped the easy out tools and the whole is slightly bigger then a bleed nipple |
measure the hole size and then get correct size; there is a whole range of bleed nipple avalible
Posted: Sat Sep 17, 2011 10:39 am |
ah i didnt read this, ignore my link to ebay item, measure the hole, also do you know what pitch the bolt was you put in? if not the hole might just have to get bigger
| WIP: Black 1.6 16v XSi
Beauté Noire | |
Posted: Sun Sep 18, 2011 2:31 pm |
New calliper time.
woops
Posted: Tue Sep 20, 2011 2:30 pm |
MrBSI wrote: |
bleeding with Peugeot Planet. |
Can you explain ?
| 2005 206 RC RED
Lot's of CNC machined customs pars. | |
Posted: Tue Sep 20, 2011 2:44 pm |
Schumi wrote: |
MrBSI wrote: |
Can you explain ? |
if you have got air in the abs pump you will need peugeot planet to activate the abs pump to bleed the air out of it.
Posted: Tue Sep 20, 2011 3:18 pm |
broadblaster wrote: |
Schumi wrote: |
MrBSI wrote: |
Can you explain ? |
if you have got air in the abs pump you will need peugeot planet to activate the abs pump to bleed the air out of it. |
Hmm. I didnt know that. I know Peugeot Planet must be used when tracking on cars with equipped ESP for steering angle sensor.
| 2005 206 RC RED
