Latest: SA01
Overall: 17138
Online Now [90]:
Visitors: 88
Members: 1
Today: 18988
Total: 112141660
Forums › The Car › 206 Talk › 206 1.4hdi fuel filter
actionman
PostPosted: Fri Sep 23, 2011 6:51 pm Up
Hi
a mate of mine wants me to service her car for her over the weekend. Just wondering what kind of a job it is to do the fuel filter?
I've looked into the parts already & it seems the whole filter housing has to be changed. Is it just a case of disconnecting the fuel pipes then removing the housing, fit the new housing then reconnect the pipes?
I'm pressuming it's a self priming system as it's not old an old car, 2007, my 51 reg vectra 2.2dti isn't self priming & was a total PITA to get it running after changing the fuel filter
Craig
Mobile remapping using the Alientech Kess V2. mobile diagnostics, fault code reading/clearing for most cars & some vans. Mobile car key cutting & programming for most makes!
PostPosted: Sat Sep 24, 2011 7:02 am Up
HDI is self bleeding BUT it can take a long while to start after a filter change Wink
qwert
PostPosted: Sat Sep 24, 2011 7:22 am Up
Huh? It starts straight away if bled right
brum brum
actionman
PostPosted: Sat Sep 24, 2011 11:55 am Up
took me hardly any time at all to change the filter, primed it & it started 1st time!
Thanks anyways guys!
PostPosted: Sat Sep 24, 2011 11:58 am Up
Yeah it's easy to change, and should start straight away when bled right Smile
