Online Now [467]:
Visitors: 466
Today: 136038
Total: 156488213
Forums › The Car › 206 Problems › 206 air bag problem
206 air bag problem
rob-p
PostPosted: Fri Sep 23, 2011 7:54 am Up
hiya had my 206 for 2 years now just over the winter and even now when the temp is below 10oc the air bag light comes on if i then restart the car it then goes off has anyone had the same problem or does anyone know how i can fix it
Many thanks
Rob
its a 2004 1.4 hdi
PostPosted: Fri Sep 23, 2011 8:03 am Up
This has been covered many times. Please search before posting.
206info.co.uk/Forums/v...20541.html
rob-p
PostPosted: Fri Sep 23, 2011 2:02 pm Up
it dosnt say anything about when its cold thanks
Deckchair5
PostPosted: Sat Sep 24, 2011 12:52 am Up
So if the outside temp is below 10C then the airbag fault light comes on straightaway? And if you restart it goes off and stay off?
As it's temp related then it's more likely to be a poor contact in the system or even within the airbag ECU. You could go around and disconnect and clean the connectors shown in the link above you can easily to get to with contact cleaner (nothing else) and reconnect but a quicker way would be to use something like Peugeot Planet and read any airbag fault codes to narrow down the area producing the fault
Disconnect the battery and leave for 10mins before working on the airbag system
qwert
PostPosted: Sat Sep 24, 2011 1:37 am Up
Battery
brum brum
PostPosted: Sat Sep 24, 2011 1:50 am Up
qwert wrote:
Battery
Good shout. The electrics go a bit funny on 206s when the charge is low.
