Latest: SA01
Overall: 17138
Online Now [1286]:
Visitors: 1285
Today: 18038
Total: 111332450
Forums › The Car › 206 Talk › Side Repeater 2 pin plug
GTW206
PostPosted: Sat Sep 24, 2011 2:23 am Up
I purchased these awhile ago.
However, I need what I believe is a 2 pin plug as the repeaters on the car is one unit.
Ebay yields no results for my searches. Are these only available from Peugeot dealers?
1.4 8v EXL
PostPosted: Sat Sep 24, 2011 2:40 am Up
The plug is two pin, can you not just splice the the wires if the connections aren't the same?
GTW206
PostPosted: Sat Sep 24, 2011 3:16 am Up
This is the existing repeater:
1.4 8v EXL
PostPosted: Sat Sep 24, 2011 3:43 am Up
You can buy all plugs and pins from the dealer - obviously you just need to work out exactly what you need.
PostPosted: Sat Sep 24, 2011 3:50 am Up
Peugeot / Citroen part number 6215 43 Bulb holder £3.12
GTW206
PostPosted: Sat Sep 24, 2011 4:08 am Up
Thank you.
1.4 8v EXL
