Latest: SA01
Overall: 17138
Online Now [4610]:
Visitors: 4609
Today: 83230
Total: 111397584
Forums › The Car › 206 Talk › what is this wire for? *pictures*
bisphenol-a
PostPosted: Sat Sep 24, 2011 3:25 am Up
found this telephone wire pin type but smaller
wasnt plugged into anything but it was hanging loose hidden behind those covers under the steering. followed the wire and it went along the drivers' side door under the carpet, hidden together with the other wires that run towards the back of the car. didnt feel like ripping out the carpets just to see where it ends Laughing . removed a door's length of carpet before giving up.
iainlovatt
PostPosted: Sat Sep 24, 2011 3:38 am Up
at a guess it looks like a remote wire for a amp!
(My Garage)
mtempsch
PostPosted: Sat Sep 24, 2011 8:30 am Up
Looks exactly like the wire and connector used by the remote gain control on my DLS amp.
Silvermetallic 2004 206 RC
PostPosted: Sat Sep 24, 2011 8:46 am Up
Ethernet.
bisphenol-a
PostPosted: Sat Sep 24, 2011 9:36 am Up
V9977 wrote:
Ethernet.
will test with my adsl modem Wink
mtempsch
PostPosted: Sat Sep 24, 2011 10:01 am Up
V9977 wrote:
Ethernet.
Perspective might be fooling me, but the plug looks more square (ie like a 4-pin RJ-11) than the more rectangular 8-pin RJ-45 normally used for ethernet.
Not that you couldn't try running ethernet over 4 wires, and the RJ-11 plug will work in an RJ-45 socket (central 4 pins), while the pairs in that kind of flat wire is, IME, not as twisted as ethernet normally wants, you could probably get away with 10 Mbps over a short run even in a fairly noisy environment.
Could of course have been used for just about anything, but my money would still be on remote gain control - are there any [other] remains from a previous sound systems install?
