Posted: Sat Sep 24, 2011 3:25 am |
Posted: Sat Sep 24, 2011 3:38 am |
at a guess it looks like a remote wire for a amp!
Posted: Sat Sep 24, 2011 8:30 am |
iainlovatt wrote: |
at a guess it looks like a remote wire for a amp! |
Looks exactly like the wire and connector used by the remote gain control on my DLS amp.
| Silvermetallic 2004 206 RC | |
Posted: Sat Sep 24, 2011 8:46 am |
Ethernet.
Posted: Sat Sep 24, 2011 9:36 am |
will test with my adsl modem
Posted: Sat Sep 24, 2011 10:01 am |
Perspective might be fooling me, but the plug looks more square (ie like a 4-pin RJ-11) than the more rectangular 8-pin RJ-45 normally used for ethernet.
Not that you couldn't try running ethernet over 4 wires, and the RJ-11 plug will work in an RJ-45 socket (central 4 pins), while the pairs in that kind of flat wire is, IME, not as twisted as ethernet normally wants, you could probably get away with 10 Mbps over a short run even in a fairly noisy environment.
Could of course have been used for just about anything, but my money would still be on remote gain control - are there any [other] remains from a previous sound systems install?
