Online Now [394]:
Visitors: 393
Today: 136427
Total: 155229036
Forums › The Car › 206 Problems › Multiplex radio
Multiplex radio
puggy206
PostPosted: Sat Sep 24, 2011 9:41 am Up
Hi all as u know just recently bought a 206 1.6 quiksilver and just had a simple question.
My friend has a gti 180 and his radio comes on straight away when he unlocks his car and stays on for 30 seconds after he takes his key out due to the bsi activating/active and the multiplexing I think I could be wrong though.
And I was just wondering should all multiplexed car radios come on when the car is unlocked or is it just a special feature in the 180?
If I can do it? How?
Thanks all
Citroen DS3
D-style +
1.6 VTI
Ghosty
PostPosted: Sat Sep 24, 2011 9:46 am Up
i think all muxcars do it, but you might want to wait for someone else to answer who has a mux car
Team > Black HDi GTi Stage 1 tuned (140bhp, 235lbs/ft)
Team > Ex HDi D-Turbo owner
W.I.P. > www.206info.co.uk/Foru...rt=15.html
PostPosted: Sat Sep 24, 2011 9:58 am Up
Thanks all
You friend either has a wiring fault & / OR an aftermarket radio Wink
Standard factory multiplexed radio shouldn't behave like this.
puggy206
PostPosted: Sat Sep 24, 2011 10:04 am Up
He does have an aftermarket radio in but I wouldn't think that would make a difference should it?
Citroen DS3
D-style +
1.6 VTI
PostPosted: Sat Sep 24, 2011 10:07 am Up
It does & its also not wired up correctly Wink
puggy206
PostPosted: Sat Sep 24, 2011 10:09 am Up
So it shouldn't do that then? Haha
Citroen DS3
D-style +
1.6 VTI
PostPosted: Sat Sep 24, 2011 10:11 am Up
Nope.
Next time when your friends car is locked, use your remote fob & press the unlock button near it.
Sometimes the BSI unit will wake up as it see's an unlock signal flaoting through the air which in turn will power the aftermarket radio up & then the BSI see's the unlock signal isnt the 1 its looking for & goes back to sleep again Laughing
broadblaster
PostPosted: Sat Sep 24, 2011 10:16 am Up
no it should not do that ,i had the same problem/fault when fitting new h/u into my 180 its proberly because he has not got it wired into a ign live and just on a permanent live that comes on and go's of when the bsi is actervated or deactervated
on a back road playing
PostPosted: Sat Sep 24, 2011 10:17 am Up
Peugeot even do an ISO adaptor harness for multiplexed 206's to fit aftermarket radios so there wired in correctly.
puggy206
PostPosted: Sat Sep 24, 2011 10:18 am Up
Well tbh I quite like the idea of my radio coming on when I unlock the car haha
Citroen DS3
D-style +
1.6 VTI
PostPosted: Sat Sep 24, 2011 10:21 am Up
Just leave the radio ON next time before you turn the ignition key OFF, next time you turn the key ON the radio will come on again.
puggy206
PostPosted: Sat Sep 24, 2011 10:22 am Up
Oh I know that but I was on about when I unlock the car haha so when I open my door the radio is already playing haha
Citroen DS3
D-style +
1.6 VTI
PostPosted: Sat Sep 24, 2011 10:24 am Up
Seems a pretty pointless feature.
mtempsch
PostPosted: Sat Sep 24, 2011 10:29 am Up
Thanks all
According to this thread there is both normal and 'extended' ignition wires available in the ISO socket.
Personally I like the extended ignition as it gives my empeg just enough time to boot before I open the door and get to hear it read out a welcome + the time/date Smile The staying on doesn't concern me as it has become automatic to press pause/mute after engaging the hand brake, unclipping the belt, and before pulling the key.
Silvermetallic 2004 206 RC
puggy206
PostPosted: Sat Sep 24, 2011 1:17 pm Up
I like the extended ignition too but I also read up on another forum that it cam f*** the bsi up?
Citroen DS3
D-style +
1.6 VTI
