Online Now [290]:
Visitors: 289
Today: 101396
Total: 157290614
Forums › The Car › 206 Problems › Gearbox & Clutch About To Go, cheaper to?
Pugsy
PostPosted: Sat Sep 24, 2011 10:46 am Up
Everythings just getting worn out so it now needs a new clutch and gearbox
had a gander at some other topics to see if its cheaper to see if its cheaper to buy a new gearbox and clutch for my pug or just call it a day and buy another car rather than throwing money at it and in 6 months time something else go wrong with it.
i know its french which doesnt help lol
but just wondering if buying both a clutch and gearbox is better than buying a new car ?
Cheers in advance Cool
(used the search button but couldnt find anything along the lines of expences, so apologies if its been posted before)
Pugsy206asw
sx206
PostPosted: Sat Sep 24, 2011 10:56 am Up
only you can answer that question.do the maths.
206
PostPosted: Sat Sep 24, 2011 11:20 am Up
Depends, how reliable/unreliable has the rest of the car been? Could you afford to change cars right now, or are you just about scraping together the cash for a new box and clutch?
Also it's better to live with the devil you know than try to live with one you dont Wink
devotedsniper
PostPosted: Sat Sep 24, 2011 12:08 pm Up
You would probably be better getting a no noise making 2nd hand box off someone breaking a 206 to be fair, it will be ALOT cheaper than a new one. The only problem with second hand is you never know when it's going to go.
If you really like the car get a new gearbox, you like it but don't plan to keep it for a good few years then 2nd hand, if you just want rid then sell but you wont get much for one with a knackered clutch/gearbox.
Now a 2010 Renault Megane Coupe owner
Pugsy
PostPosted: Sat Sep 24, 2011 12:26 pm Up
its been pretty reliable up and til now not had any problems til the comm went hay wire and then my clutch and gearbox decided break
I'm quite attached to it as its my first car so know all the in's and outs on it Smile depending on how bad it is i'll throw a bitta cash into it as like leethr says i'm not exactly rolling in money.
Cheers for the advice guys Smile
Pugsy206asw
shaft
PostPosted: Sun Sep 25, 2011 2:17 pm Up
Ive just rebuilt the MA box from my 1.4 SW due to an unknown noise, it turned out to be the Pinion bearing that was the culprit. Total parts replaced where a full set of bearings & seals and a new set of planet gears for the box, fitted a new clutch also. Total cost £185, but i did do the work myself.
HTH,
Nick.
Man make? ------ Man fix!
colganraz
PostPosted: Tue Sep 27, 2011 9:14 am Up
clutch and gearbox, around £700 fitted i would put it at if its a refurb, can you be fully sure both are nak'd? could be something alot smaller
PostPosted: Tue Sep 27, 2011 11:28 am Up
HTH,
Nick.
sounds about right; normal gearbox rebuild kit cost around 80-90 (think is 5 bearing and 3 seal)
clutch is 100 or so.
