Latest: DanDan17
Overall: 17128
Online Now [96]:
Visitors: 95
Today: 15863
Total: 100490667
Forums › The Car › 206 Talk › How to remove the front badge?
boyracer93
PostPosted: Sun Sep 25, 2011 5:38 am Up
How do you remove the whole front badge for spraying?
craigy00craig
PostPosted: Sun Sep 25, 2011 5:46 am Up
you can either remove the entire badge and you need to remove the front grille and then use a hex key to screw the whole badge off.
If you just want the V and the lion, just get a tiny flat head screwdriver and pry them off. Be very careful around the lions tail as this snaps very easily (it happened to mine) but you can just glue it back together and you cant see the break after its been painted.
Progress Threads:
PostPosted: Sun Sep 25, 2011 5:50 am Up
You could of easily used the search function here
www.206info.co.uk/Foru...t=559.html
boyracer93
PostPosted: Sun Sep 25, 2011 6:01 am Up
I did but that didnt include much info about taking it off?
Thanks though craig Smile will probably get it done this afternoon
craigy00craig
PostPosted: Sun Sep 25, 2011 6:12 am Up
no worries, im changing mine from red to white today so will be doing this as well. Also, get some superglue incase you break any of the clips on the back of the lion.... i broke a lot of bits when i did mine last time Razz
Progress Threads:
