Latest: flipflap
Overall: 17140
Online Now [371]:
Visitors: 370
Today: 66577
Total: 113866534
Forums › The Car › 206 Problems › Engine idol runnin a bit too low
Gaz360
PostPosted: Sun Sep 25, 2011 9:19 am Up
Hi, was just wandering if anyone knew how to lift the engine idol a tiny bit.
When its warmed up it runs at about 800 ish. I think thats too low and rocks the engine a little and gives it an opportunitiy to stall as well. Just wanted to lift it 2 0r 300 more to help it run a bit smoother.
206 gti v plate.
PostPosted: Sun Sep 25, 2011 9:28 am Up
Why? That idle is correct.
PostPosted: Sun Sep 25, 2011 9:32 am Up
Not sure what the idol is, but like Tom said the idle is fine
PostPosted: Sun Sep 25, 2011 9:52 am Up
that idol is fine mate, mine is currently idling at 550rpm but doesn't feel like it's going to stall at all, even my local garage advised me that it's running ok then it's ok to leave it for a while as it will cost £167 to supply and fit new idle control valve
PostPosted: Sun Sep 25, 2011 9:54 am Up
1k idle will fail mot test.
Gaz360
PostPosted: Sun Sep 25, 2011 9:55 am Up
most of my other cars have ran a bit higher is all. will leave it then if it sounds ok... the IDLE that is lol. thanks
Ash
PostPosted: Sun Sep 25, 2011 11:21 am Up
Why would it?
PostPosted: Sun Sep 25, 2011 11:27 am Up
Emissions would be too high
Deceitful
PostPosted: Sun Sep 25, 2011 11:40 am Up
clean out the map sensor sometimes they get filled with crap if that fails try adjusting the throttle cable might be abit loose or the clip may of pinged off
Peugeot 206 Zest 1.1 5 door
lee206xsi
PostPosted: Sun Sep 25, 2011 12:00 pm Up
1200 idle on cold (;
Leon Cupra - 210bhp
booooosssssttt
www.facebook.com/lee1989
