Latest: DanDan17
Overall: 17128
Online Now [71]:
Visitors: 70
Today: 21098
Total: 100541013
Forums › Tuning, Modification & Legal › Project Cars › Mr Cellexe's GTi Road Legal Track Project
Mr_Cellexe
PostPosted: Sun Sep 25, 2011 11:31 am Up
Some of you know it, some of you dont. from the top then! Smile
1999 (V) Peugeot 206 GTi
started life as this
completely standard, no factory upgrades whatsoever.
5days before USC 2008 she looked like this courtesy of some borrowed shadow chrome vortex alloys.
eventually they had to be given back. so back to standard 15" rims it went.
a few months past and the modifications had started.
new drilled and grooved discs at the front with EBC greenstuff pads.
Spax adjustable shocks with Koni -40mm springs upfront and the rear beam lowered to match.
After driving some 5000 miles later, i got a blow in the center box. out came the entire system and in plonked a cat back PowerFlo exhaust system with 3" slash cut tip (excuse the pic! i cant find half the decent ones)
by this time i'd also changed the Headunit to a Pioneer 6.5" motorised DVD and bringing with me from the 307, the Vibe components, Rockford Punch P1 subs and the 1000w Amp.
these got sold and changed for a custom fit Pioneer comp set up front, a single 12" Pioneer sub, 400W amp and an Alpine CD/MP3/Bluetooth headunit.
The interior plastics got a make over too. went from moonstone blue, to gloss black, to white before i stopped! lol.
Some small exterior changes were made with the addition of an SP spoiler, SP arches and SP Fuelcap.
Managed to get the alloys sanded down, painted alpine white and back on within a weekend! lol.
smoked rear clusters and got my chequerplate mats Smile
mudflaps
Lockwood white dials
sunstrip and vento vr6 splitter
And so, the last time she saw the road, she looked not a million miles from this
to be continued.......
kingsway2468
PostPosted: Sun Sep 25, 2011 11:37 am Up
looking tidy mate not a fan of the mud flaps tho
d roth
Mr_Cellexe
PostPosted: Sun Sep 25, 2011 11:38 am Up
ok, so as of June 2010 i had her SORN'd. then proceeded to do this
thats how she stayed for the winter. and when things started to warm up a little, me and a mate (who is now sharing the driving responsiblilties! lol )got to work.
Little while later i had a few days off work for the purpose of
and got it to this stage...
to be continued....
Mr_Cellexe
PostPosted: Sun Sep 25, 2011 11:59 am Up
After the shenanigans of painting and undersealing, we set about replacing the old crappy rubber suspension bushes with some nice tight poly bushes.
This proved a tad more difficult than we first thought. We had a nightmare finding someone that did all the ones we needed (ironically Superflex and Powerflex both do kits now!)
Anyway, we ran with SuperPro. We have there lower arm (single offset) bushes, front Anti Roll Bar bushes and rear lateral beam supplement washers which stiffen up the OE mount bushes.
no problems with the ARB and lower arm bushes. and i know my mate (from here on known as Oggy) had fun with the press! lol
So we rebuilt the front end, withthe already painted subframe, ARB, lower arms and a nice clean steering rack!
Rear beam however is a different story!
we did manage to get it like this
Before having to take it apart after stupidly trying to remove the OE bushes ourselves!. so that getting the arms off, removing the torsion bars, which was a pig as we sheered a torx headed bolt! (opps). Once it was apart we found knackered needle roller bearings which still need to be replaced. Also when replaced it was found that the old OE mount bushes had pretty much rusted away inside with a big hole in one of them. That said, Oggy had more fun with the press and it looks like this now.
we still need to refit the arms and bars etc but as far as bushes go its sorted! lol
To be continued....
Mr_Cellexe
PostPosted: Sun Sep 25, 2011 12:02 pm Up
I painted up a plethora of other parts
the calipers are going in to be sand/bead blasted as there is too much previous paint on them and the paint job looks like s**t because of it
I got bored waiting for parts and generally wanted something to do so...
to this
To be continued...
Mr_Cellexe
PostPosted: Sun Sep 25, 2011 12:03 pm Up
And to bring the project upto date...
after getting the parts i was waiting for
two wilwood master cyclinders. one .625 and the other .700
remote bias adjuster
seperate fluid resevoirs (I did get mounting brackets, a double for the brake cyclinders and a single for the clutch)
three of these resevoir to cylinder drop pipe kits
Copper brake pipe, new unions and T-pieces (not pictured)
so, having spent an age putting together and setting up the bias box we went to fit it and work out where the pipes etc would be run.
trial fitted the remote adjuster. its a trick little touch for those 'on track' brake adjustments! lol.
spent a bit of time on the placement of the resevoir pots too! lol.
also fitted the new clutch cylinder (well, i say new, i've had it for two years!)
and lastly, both mine and Oggys fave part!
350mm Black suede Rally steering wheel with 3" dish Smile (excuse the clingfilm)
thats pretty much where it stands atm. we've got a few small bits to do before we run the brake lines and clip them down, but, its moving at a steady pace!
PugJH
PostPosted: Sun Sep 25, 2011 12:14 pm Up
coming along nicely
WIP: Black 1.6 16v XSi
Beauté Noire
PostPosted: Sun Sep 25, 2011 1:23 pm Up
It's amazing where all the ££££'s go and it's not even on its wheels...
PugJH
PostPosted: Sun Sep 25, 2011 1:39 pm Up
What was the total cost of the bush and bones?
Beauté Noire
Mr_Cellexe
PostPosted: Sun Sep 25, 2011 2:05 pm Up
this is very true! although i've not really spent that much. circa 500 quid so far.
ermm, roughly 100 quid.
because its been done in stages i've not kept a major track of it tbh.
macj
PostPosted: Sun Sep 25, 2011 11:31 pm Up
good start mate..... liking the way your thinking Wink
dumdum0910
PostPosted: Mon Sep 26, 2011 1:35 am Up
cant wait for this to be on the road Smile coming along nicely fella
Mr_Cellexe
PostPosted: Mon Sep 26, 2011 6:10 am Up
coming from you, i know im on the right track Smile
dumdum0910 wrote:
cant wait for this to be on the road Very Happy coming along nicely fella
yea, neither can i! lol. btw, LOWER your damn car! hehe
WOOP!! pipe clips arrived this morning, so we can get to work on the brakelines. still need some braided hoses for the rears tho.
To waste time whilst the funds recover, we're gonna get the loom/electrics sorted. chop out the unwanted crap and rewrap it, bind it all in.
More pics as it happens.
macj
PostPosted: Mon Sep 26, 2011 10:54 am Up
I ran cupro-nickel pipe inside the car to the rear, "T" piece under the floor and solid to each side and used flexi brake pipe to the calipers. Bearing in mind I have hydraulic handbrake. I assume with the bias pedal box you will run one pipe to rear Wink via the handbrake cylinder (if used). It also means you can get on without waiting for the hose to come Laughing
Electrics are fun on the 206 as the French earth everything a thousand times when one common earth would do. I did what you are doing and split the original loom and junked all the rubbish. Are you going to use standard ECU?
Mr_Cellexe
PostPosted: Mon Sep 26, 2011 2:52 pm Up
Yep standard ecu and funny enough exactly that with the brakes! Just minus the hydraulic handbrake (keeping the costs down as a normal
Handbrake will be sufficient ATM).
I'm yet to believe the 'fun' part of the loom (even if I am
An electrician by trade! Lol). We shall see what goes
On but I'm sure it'll have plenty cut out as alot of other stuff is out too, like abs and aircon Smile
