Latest: sparrowdclxvi
Overall: 17139
Online Now [154]:
Visitors: 153
Today: 40058
Total: 113239947
Forums › The Car › 206 Talk › lamba sensor
lamba sensor
Gaz360
PostPosted: Tue Sep 27, 2011 8:43 am Up
Does anybody know if I have 2 lamba sensors. its a 99 206 gti. I thought it was the 180s that had 2.
PostPosted: Tue Sep 27, 2011 8:53 am Up
1 before the cat
Gaz360
PostPosted: Tue Sep 27, 2011 8:56 am Up
Thanks lee
PostPosted: Tue Sep 27, 2011 9:12 am Up
Any level 4 emmisions petrol 206 will have 2 lambda sensors.
My 03 plate TU3 has pre cat & after cat lambda sensors.
gazza82
PostPosted: Tue Sep 27, 2011 10:50 am Up
Our 2001 CC 2.0i has two: one pre, one post. Same lambda sensor (LS615) but different connectors.
Gaz360
PostPosted: Fri Sep 30, 2011 8:13 am Up
Ok thanks for that. Need to get hold of one if you recommend anywere or know anyone who is selling one
PostPosted: Fri Sep 30, 2011 8:26 am Up
GTi's chassis coded RFN = 2 x lambda, RFR = 1 x lambda.
Gaz360
PostPosted: Fri Sep 30, 2011 9:09 am Up
just checked and mine is rfr. Thanks
PostPosted: Fri Sep 30, 2011 12:12 pm Up
Wink
leigh_boy
PostPosted: Sat Oct 01, 2011 1:13 pm Up
i have a genuine pug one from my old gti that i broke up u can have for £8 posted?
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
Gaz360
PostPosted: Thu Oct 06, 2011 2:58 am Up
sorry leigh. forgot to to reply. have got one now but thanks anyway. priciate the offer.
