Latest: Andyblue64
Overall: 17123
Online Now [300]:
Visitors: 299
Today: 60532
Total: 98332100
Forums › The Car › 206 Problems › Squeeking noise coming from wheel
Reflekt.
PostPosted: Wed Sep 28, 2011 8:20 am Up
Right, ive had this problem since ive had the car. Everytime i turn left doing say over 10mph, and hit a small bump/pothole in the road i get a bit of a knock and a weird squeeling noise. Sounds a bit like a seal? lol!
Also if turning a bit hard at speed (30mph) the car doesnt feel safe atall
I replaced the drop links this morning and the track rod ends look fine, and the noise is still haunting me!!
Could it the be top mounts making it do this? Anything else i should consider?
Thanking you.
2.0 HDi Moonstone Blue Progress Thread
2.0 HDI... Carbon front badge, Black rear lights, PH2 bootstrip, Honeycombe grill
PostPosted: Wed Sep 28, 2011 8:36 am Up
Checked the ball joints?
deebee
PostPosted: Wed Sep 28, 2011 8:38 am Up
i know im dumb but i had similar probably it was driftshaft
Breaking 2.0 hdi with ps and gti bits
Reflekt.
PostPosted: Wed Sep 28, 2011 8:42 am Up
Sorry to sound a noob but what ball joints? and where are they?
Reflekt.
PostPosted: Wed Sep 28, 2011 8:43 am Up
My cousin also said this!
This cars turning out to be more hasle than its worth!
PostPosted: Wed Sep 28, 2011 8:45 am Up
Part of the wishbone
Reflekt.
PostPosted: Wed Sep 28, 2011 8:47 am Up
Ah i see, didnt know it was refered as a ball joint lol.
Ive had a look at it and it looks ok... but im no pro. any tell-tale signs it would need replacing?
PostPosted: Wed Sep 28, 2011 8:49 am Up
Knocks when you go over bumps and squeaks some times Laughing
Reflekt.
PostPosted: Wed Sep 28, 2011 8:51 am Up
haha point made! Will re-greasing it help? or is it a new wishbone job?
PostPosted: Wed Sep 28, 2011 8:53 am Up
Get it checked before replacing it.
Just replace them if it's worn, not too expensive
Reflekt.
PostPosted: Wed Sep 28, 2011 8:57 am Up
cheers mate ill have another look now, if im left scratching my head ill give up and get my mechanic to have a look!
Thanks again dude ill keep this thread updated for anybody else struggling!
Reflekt.
PostPosted: Wed Sep 28, 2011 9:32 am Up
Wishbones look ok, Just checked the driveshaft and It was all oily, wiped it clean took it for a spin and there's oil again? But would a drive shaft be making a noise like that going over an uneven road?
ExoVyper
PostPosted: Wed Sep 28, 2011 10:56 am Up
sounds like the cv boot has split if the oil/grease is near the wheel.
also did you jack your car up and put a bar inbetween the hub and the ball joint to check for play? as just looking at it won't show any faults
Reflekt.
PostPosted: Wed Sep 28, 2011 11:36 am Up
There's oily stuff at the gearbok end of the driveshaft, and yes no play in the ball joint atall.
mjrimmer
PostPosted: Wed Sep 28, 2011 11:49 am Up
Could still be the wishbone though, theother 2 bushes tend to go. Mine had one of the front bushes shot causing it to knock on hard acceleration and sound like the car was about to fall to bits over any rough stuff off the throttle.
I could't fault it until I got it on the ramps at my local garage where I could get a pry bar in it and compare it to the other side.
206 gti 180
