Posted: Thu Sep 29, 2011 7:46 am |
Hhi guys ive had a quick search but cant find what im looking for, basically ive recently switched back to standard steelies (175,65 R14) from 16" nimrods and have had a rubbing/grinding noise from front of the car, any ideas what it may be?
my car is a 206 1.4 verve 2006 plate if it helps.
Also i had an advisory for passenger side wishbone... not sure if this would effect the wheels rubbing?
Posted: Thu Sep 29, 2011 8:34 am |
Is it standard height?
| Ran off with a Honda Integra DC5 Type R
Cya! | |
Posted: Thu Sep 29, 2011 8:41 am |
yeah mate, standard
Posted: Thu Sep 29, 2011 9:04 am |
I take it you are using the correct steel wheel bolts for the steel wheels & NOT the alloy bolts from the Nimrod's?
Posted: Thu Sep 29, 2011 11:08 am |
brake pads worn down? check if the front discs are still smooth
| Slowly taking shape.. Progress thread up soon | |
Posted: Thu Sep 29, 2011 3:39 pm |
Someone stacked wheel weights inside one of the wheels for some reason? they can catch the caliper.
Posted: Thu Sep 29, 2011 3:43 pm |
MrBSI wrote: |
I take it you are using the correct steel wheel bolts for the steel wheels & NOT the alloy bolts from the Nimrod's? |
I thought this as soon as i read the question.
