Latest: DanDan17
Overall: 17128
Online Now [220]:
Visitors: 219
Today: 24279
Total: 100584952
Forums › The Car › 206 Talk › Antifreeze
Antifreeze
Seb
PostPosted: Mon Sep 05, 2011 11:34 am Up
Staff - Seb
Nope, water is fine.
PostPosted: Mon Sep 05, 2011 11:43 am Up
Seb wrote:
Seabook wrote:
all those green/blue or pink coolant are just color additive which makes it easier for you to check your level and to change the coolant.
That's wrong. 99% of the time, the blue (MEG)/green is inorganic and the pink/orange (+OAT) is organic. If you mix them it will silt the coolant system.
Most of the old green coolants should not be mixed with ANY type of coolant, as it will probably silt anyway, but definately don't mix a non OAT with an OAT coolant, ie, blue and pink.
i did say don't mix antifreeze Laughing
and the color system is not a reliable method to guess what anti rust reagent is in there
eddrj
PostPosted: Mon Sep 05, 2011 12:37 pm Up
ok cool ,water it is lol battery ,de -ionised water
just not the hard shi*t round my area i dont even drink out of tap here .
Old car 2000/ 206 2.0 hdi.
eddrj
PostPosted: Sun Sep 18, 2011 10:29 am Up
my antifreeze must be OAT surely thats long life and on new cars ,and mine says dont need to change antifreeze in manual.
Also the blue stuff is changed every 2 years and for older cars.
Isnt yellow metals in older cars aswell which you cant mix the OAT coolant with.
I have the pink OAT adavanced antifreeze long life wouldnt that be ok to use ??
I topped it up with water a bit but dont wanna too much worried it will freeze in winter , so wanna put little bit antifreeze in .
Also is Citreon antifreeze same as peugeots ? would have thought so as it has citeron badge next to the peugeot one on all parts and expansion bottle because i have some of that in my house too as someone in family has a citeron.
eddrj
PostPosted: Mon Sep 19, 2011 10:46 am Up
just phoned peugeot they said can use any blue antifreeze.
PostPosted: Mon Sep 19, 2011 4:11 pm Up
No way?!
eddrj
PostPosted: Tue Sep 20, 2011 12:21 am Up
yeah thats what they said , my mechanic ex peugeot said blue stuff too , and all 207 pugs have blue stuff makes sense.
PostPosted: Tue Sep 20, 2011 2:08 am Up
Peugeot uses BASF Glysantin® G33 which is Blue but is actually OAT (usually red).
Hence the 5-year service life. I wouldn't be inclined to top-up with anything else tbh.
Check it out: www.glysantin-der-schu...w-How.html
+1
eddrj
PostPosted: Tue Sep 20, 2011 11:09 pm Up
i got genuine peugeot stuff so ok yeah its blue , pug def told me anyblue though
eddrj
PostPosted: Tue Sep 20, 2011 11:21 pm Up
i have blue genuine antifreeze but its concerntrated is it 50 50 mix with water or ..???
PostPosted: Tue Sep 20, 2011 11:36 pm Up
Yep. 50/50 if it needs diluting.
Use de-ionised water though!
eddrj
PostPosted: Fri Sep 30, 2011 12:29 am Up
ok
Does using air con alot use some antifreeze ? would make sense then i use air con all time .
mjrimmer
PostPosted: Fri Sep 30, 2011 1:32 am Up
eddrj wrote:
ok
No you air con is a closed system and uses gas to cool (works a bit like a fridge)
206 gti 180
eddrj
PostPosted: Fri Sep 30, 2011 2:25 am Up
o i got told using air con all the time will use bit antifreeze
so it not using any antifreeze atall ?
Does it make a diffrence as mine has climate control or not ?
i have to use air con almost all the time because when you press the windscreen or rear screen de mister button air con automaticly comes on with it .
PostPosted: Fri Sep 30, 2011 2:27 am Up
they don't
and in fact antifreeze will be not "used up" in any occasion
Page 2 of 4
