Online Now [1341]:
Visitors: 1340
Today: 190133
Total: 155279819
Forums › The Car › 206 Problems › induction kit / air filter --- causing anti pollution fault
supercows
PostPosted: Fri Sep 30, 2011 2:07 am Up
hi there,
has anyone got any suggestions for me,
whenever i have attached an induction kit to my 206 gti 137 bhp it always seems to trigger the anti pollution fault sending it into limp mode.
i would really like to get this fixed if anyone has any ideas? ?
regards...
supercows
Matt
PostPosted: Fri Sep 30, 2011 2:45 am Up
Trade Rating: +32
dont put an induction kit on it then.
just buy a panel filter.
supercows
PostPosted: Fri Sep 30, 2011 2:51 am Up
ive gone with the panel filter as a worst case scenario
but i prefer the sound and drive of the car with the full kit if possible along with the full stainless exahst system thats all .....
supercows
Mattie-RS
PostPosted: Fri Sep 30, 2011 6:59 am Up
But the Induction Kit wont improve the drive of the car, 11 times outta 10 it decreases Torque and BHP
Matt
PostPosted: Mon Oct 03, 2011 3:14 pm Up
Trade Rating: +32
just get a decent exhaust then.
Andrew
PostPosted: Mon Oct 03, 2011 4:55 pm Up
Is it an open cone induction kit? Warm air is sparse so the engine might not be giving the right amount of air/fuel mixture
Standard setup with a good panel filter should be fine, but if you want an induction kit that won't bring up the faults, one that draws air from a cold area and is shielded from heat would be the best and would most likely avoid the problem.
My 206 thread
www.detailedbyandrew.com
leigh_boy
PostPosted: Tue Oct 04, 2011 4:18 am Up
you need to re position the filter as its sucking in hot air.
*DEAD*206 Gti 138
Toyota Celica T sport 205 BHP
Lewis
PostPosted: Tue Oct 04, 2011 4:43 am Up
like many people have said on this forum before.. decent panel filter in the standard air box.. Peugeut put the air feed in the wheel arch for a reason!
Tivoli LX 1.1
Black GTI 180
White VXR Burg
tailhappy
PostPosted: Thu Dec 22, 2011 9:18 pm Up
i have the same probably but as i see it let the man have a induction kit on the car as it does make a difrence im sure there is a way around the problem Smile ..... i.e (ignore it ) Very Happy
jamie bennett
