Latest: DanDan17
Overall: 17128
Online Now [386]:
Visitors: 385
Today: 68310
Total: 100668661
Forums › The Car › 206 Problems › 206 gti 180 air con leak
ramigojag
PostPosted: Fri Sep 30, 2011 10:02 am Up
I believe this is a common problem but couldnt find anything in a search.
I had my air con regassed today and its all leaked out got it up on the ramp today at work and have seen one of the pipes has rubbed smooth against another and can only assume there is a pin p***k hole in it.
Has anyone developed a fix for this or is the only way a new pipe?
cheers
callum
PostPosted: Fri Sep 30, 2011 10:33 am Up
New pipe only and if it's the main one from the bulkhead along the inner wing it would be a nightmare to replace.
PostPosted: Fri Sep 30, 2011 12:19 pm Up
No pressure check or vacuum check carried out then before the system was recharged?
ramigojag
PostPosted: Fri Sep 30, 2011 12:23 pm Up
yeah there was the machine wont let them put it in if it doesnt hold the vacuum for a certain amount of time the only thing i can see has happened is it was gassed while the two pipes (which have rubbed off each other) were touching so it appeared to be sealed but then under the pressure whilst the air con was on the two pipes have pulled apart and revealed the small hole
brad-morris
PostPosted: Fri Sep 30, 2011 12:29 pm Up
There must of been some force behind that pipe to stop the pressure coming out ?
ramigojag
PostPosted: Fri Sep 30, 2011 12:33 pm Up
obviously because that same pipe is the one thats been rubbing away and has managed to wear right through the metal so is obviously some pressure im guessing just from poor build quality ive heard its a common problem with the 180s
PostPosted: Sat Oct 01, 2011 1:43 am Up
Can't say I've heard of any problems before. Must be just yours. My 138 GTi held its gas for over 10 years and worked perfectly.
Deckchair5
PostPosted: Sat Oct 01, 2011 2:45 am Up
have seen one of the pipes has rubbed smooth against another and can only assume there is a pin hole in it.
Well I wouldn't assume that is the source of the leak, could be a lot of work for nothing
A vacuum check may be fine but then it's totally different when the system is working and the pressure goes positive and certain parts are up to much higher temperatures. Metal expands and leaks show up
I'd identify where the leak actually is before attempting any work
kit325
PostPosted: Sun Oct 02, 2011 5:53 am Up
Check your pipe if there's any excessive wear specialy on the sectin where the pipes rubbed together. When reggassing, ask mechanic to add uv dye into your system. If there is any leakeage, the uv dye in your air-con system should indentify whre's the leakeage is.
PS: I have same problem where there are two pipes rubbed together. I fix it by tie up 2 thick cable tie into each pipes at the contacting point to prevent 2 pipes from rubbed into each other.
kit
