Posted: Sat Oct 01, 2011 1:15 pm |
Well i was reversing onto the garden earlier and i noticed in the reflection of the greenhouse behind me that my reversing lights weren't working, sat for a while putting it back in neutral and then back into reverse and they still weren't working and then all of a sudden they just started working again.
Just been onto the garden to check again and it did the same again, no reverse lights coming on and after about 5 times of putting it in reverse they all of a sudden started working again.
Has anyone ever had this problem before, ive done a quick search on here and only found problems where peoples reverse lights werent working at all.
If it was a fuse or the reversing switch that was at fault then wouldnt the reverse lights just not work at all instead of not working and then all of a sudden working again?
Thanks for any help in advance, oh and i have a 2004 1.6 xsi model if that helps
Posted: Sat Oct 01, 2011 1:18 pm |
either a bad connection or the reverse sensor on the gear box may have a bad connection or need replacing
| *DEAD*206 Gti 138
Toyota Celica T sport 205 BHP | |
Posted: Sat Oct 01, 2011 1:29 pm |
Yeah myt just be a loose connection! Take the plug out and plug it back in!
Posted: Sat Oct 01, 2011 1:34 pm |
onThe plug on the sensor that sits ontop of the gearbox do you mean? How easy is this to get to? Thanks
Posted: Sat Oct 01, 2011 1:51 pm |
No i mean to the rear lights themselfs!
Posted: Sun Oct 02, 2011 1:42 am |
StephXSi wrote: |
onThe plug on the sensor that sits ontop of the gearbox do you mean? How easy is this to get to? Thanks |
i would be looking more at gear box engm dirty contact or similar, normaly on the bottom / end of the gear box.
| *DEAD*206 Gti 138
Posted: Sun Oct 02, 2011 2:15 am |
| WIP: Black 1.6 16v XSi
Beauté Noire | |
Posted: Sun Oct 02, 2011 2:16 am |
Check the fuse first of all. Don't just look at it, use a multimeter to check it hasn't blown.
Disconnect the connector from the gearbox reversing switch, select reverse gear (engine turned off) and using the continuity setting on a multimeter check if the switch is working.
If it's working check to make sure there is current reaching the bulbs. Again using the multimeter (change setting to measure DC 12v) remove one of the bulbs and touch the multimeter probes onto the bulb holder connections. You will need the ignition on and reverse gear selected. BE CAREFUL NOT TO SHORT ANYTHING OUT when doing this stage.
If you have current reaching the bulbs, then check the bulbs themselves haven't blown.
Posted: Sun Oct 02, 2011 2:26 am |
Trade Rating: +46
not needed for mot anyway so wouldent worry..
Posted: Sun Oct 02, 2011 4:04 am |
Would have thought you would have needed your reversing lights working for your mot? Will check the fuse first then check the reversing switch. I've had a look in my manual and can't seem to find which fuse is for the reversing lights? Does it have a fuse for those? My fuse box is underneath the steering wheel if anyone can help me with what fuse I need to check. Thanks guys
Posted: Sun Oct 02, 2011 4:06 am |
shell-vt wrote: |
not needed for mot anyway so wouldent worry.. |
Why wouldn't you? :S
Posted: Sun Oct 02, 2011 4:07 am |
Trade Rating: +46
check mot regs or ask anyone who works in a garage..
Posted: Sun Oct 02, 2011 4:10 am |
Front fogs and reverse lights aren't tested on a MOT
Posted: Sun Oct 02, 2011 4:11 am |
Lee wrote: |
Front fogs and reverse lights aren't tested on a MOT |
Hmmm.. Never knew that. They are one of our daily van checks at work, so presumed that they were. (I knew fogs weren't).
Posted: Sun Oct 02, 2011 4:19 am |
Nah, they aren't required by law so are classed as accessory lights and not MOT testable
