Latest: tebas93089
Overall: 17179
Online Now [135]:
Visitors: 135
Today: 103570
Total: 137954509
Forums › The Car › 206 Problems › Gti 180 brake problem
Andy180
PostPosted: Sun Oct 02, 2011 6:35 am Up
Hi i changed my 180's brake master cylinder yesterday it was all going really smoothly until ive come to bleed the brakes i can't get any pressure at all the pedal just drops straight to the floor, am i now right in thinking it will need pressure bleeding on peugeot planet or at a garage who has similar equipment?.
GTI 180
PostPosted: Sun Oct 02, 2011 6:37 am Up
180 brakes need to be bled using PP IIRC. How far away from Sheffield are you?
Andy180
PostPosted: Sun Oct 02, 2011 6:40 am Up
About an hour and a half.
GTI 180
PostPosted: Sun Oct 02, 2011 8:02 am Up
Another 180 with non working brakes thanks to DIY repairs Laughing
2nd one in the last few weeks Rolling On The Floor Laughing
Andy180
PostPosted: Sun Oct 02, 2011 8:09 am Up
Yeah dead funny Mr bsi Rolling Eyes
GTI 180
Brian
PostPosted: Sun Oct 02, 2011 9:05 am Up
Trade Rating: +31
Thanks for posting this! I was going to change the brake fluid myself but won't do it now knowing this!
PostPosted: Sun Oct 02, 2011 9:08 am Up
There has been enough warning posted up on here over the years about the 180 brake system needing Peugeot Planet to bleed it Wink
Andy180
PostPosted: Sun Oct 02, 2011 10:21 am Up
Fair enough, can't see why you found it so funny though Confused .
GTI 180
Daniel206RC
PostPosted: Sun Oct 02, 2011 10:36 am Up
I changed my brake fluid 3 weeks ago, I have no problems braking Razz
why do you need PP to bleed it?
03, RC / GTI180
03, SW XSI
PostPosted: Sun Oct 02, 2011 10:49 am Up
If you manage to get air inside the abs hydraulic modulator while attempting to bleed the brakes you will then need to activate the valves inside the ABS / ESP unit to bleed the system successfully Wink
Daniel206RC
PostPosted: Sun Oct 02, 2011 11:36 am Up
okey, I changed to Brembo calipers and then changed the brake fluid with pressure on the system.
So maybe I made it without getting air into the system..
03, RC / GTI180
03, SW XSI
PostPosted: Sun Oct 02, 2011 11:54 am Up
So in fact this could apply to all 206's with ABS. You dont need PP, You just need to do it properly.
PostPosted: Mon Oct 03, 2011 8:04 am Up
Nope, only 206's with ESP fitted which is GTI 180 / RC & some newer GTI's.
If you do manage to get air inside the hydraulic modulator you WILL then need Peugeot Planet to bleed the brake system.
EuroPeugeot
PostPosted: Mon Oct 03, 2011 8:09 am Up
I fitted brembos a while back, along with a new master cylinder. And I couldn't get any pressure in the system either.
Ended up taking it to a friend's garage who pressure bled it. Pretty sure they didn't use Peugeot Planet thou..?
Andy180
PostPosted: Mon Oct 03, 2011 2:51 pm Up
Its getting trailored to a mates garage to be pressure bled now.
GTI 180
