Latest: Kifi69
Overall: 17183
Online Now [563]:
Visitors: 562
Today: 156418
Total: 144447854
Forums › The Car › 206 Problems › Rattle under car rear
TomMessenger
PostPosted: Thu Oct 06, 2011 7:45 am Up
Hi all,
For the last few weeks/months I've been able to hear/feel a rattle towards the back of the car and have unsuccessfully tried several times to identify it.
I've been under the car banging various things to see what made a noise, and came up with the following:
Spare wheel basket - removed (spare wheel is dangerous and unscrews itself anyway)
Exhaust Pipe - haven't changed anything since before rattle began. Rubber "holders" are fine
Heat Shield (against what I think is the handbrake cable) - have wedged it with foam
This rattle is very prominent when going down a bumpy road at any speed, or when I go through 60-65, it turns into a constant "du-du-du-du-du-du-du" noise from the same area and I can feel it in the bottom of my seat. As far as I know, wheel/tyre balance should be fine. It sounds almost metallic.
Today though, when banging things with my palm under the car, I noticed the fuel tank sounds as if there's a ping-pong ball in there. It's a loud bouncy, echoey noise which could potentially be the thing I'm looking for. Is that possible/normal?
Anyone got any more suggestions?
There's another noise coming from the front divers side wheel area that sounds like a screw being shaken in a metal tub when going over bumps. Nothing seems loose that I can see.
Sorry for the essay!
Cheers,
Tom
Tom
www.me-strings.co.uk - Day Job
www.tommessengerphoto.com - Occasional Job
tommessengerphoto.com/page7.htm - Fishy Stuff
PostPosted: Thu Oct 06, 2011 7:57 am Up
When we took our 205 apart we found an old fuel pump that had been dropped into the tank! Could be the same for you?
PostPosted: Thu Oct 06, 2011 8:03 am Up
Exhaust baffles?
glenpring
PostPosted: Thu Oct 06, 2011 8:11 am Up
drop links for the last problem maybe??
coopskin
PostPosted: Thu Oct 06, 2011 8:47 am Up
Trade Rating: +13
Does the car slow in anyway? As if you have rear drums the shoes in the drum could of broken and be rolling about in the drum. Either that or your rear suspension beam and torsion bars are knackered
TomMessenger
PostPosted: Thu Oct 06, 2011 8:51 am Up
Thanks for your thoughts - I think I might have found something. If I really push the exhaust mid-section, it does hit the underside of the car. I thought it was coming from further back than that, but it would explain why I can feel it through my seat!
Is there anything that resists those sort of temperatures that I could wrap around it to stop it hitting?
Antknee
PostPosted: Thu Oct 06, 2011 8:56 am Up
Keep the wheel in your boot, if you break down AA and RAC wont come out to you, with greenflag its 50/50 Razz
Will180
PostPosted: Thu Oct 06, 2011 10:17 am Up
what about cars without a spare wheel lol
04/07/10. Black 206 XS 1.6 - Sold
29/03/11. Black GTI 180, Full Sp Kit
PostPosted: Thu Oct 06, 2011 10:18 am Up
They normally have the crappy tyre weld stuff that ruins the tyre.
Will180
PostPosted: Thu Oct 06, 2011 10:56 am Up
i know that but would the AA or RAC hold that against the person and not come out? lol
PostPosted: Thu Oct 06, 2011 11:13 am Up
I woudnt want to be wrapping anything around the exhaust, I'd rather get it fitted properly so it wasn't hitting anything. As for feeling heat from it through your seat Shocked
PostPosted: Thu Oct 06, 2011 12:38 pm Up
I would have thought that he would be feeling the vibration through the seat...
TomMessenger
PostPosted: Fri Oct 07, 2011 2:24 am Up
Yes I can feel the vibration/banging, not the heat!!
I need some welding done underneath next month, so I will get it looked at properly when it's on the ramps. I just wanted to stop it banging until then. A closer look at the exhaust showed it doesn't quite follow the groove in the floor - it's a couple of inches to one side, so that's the problem.
longeatonlad
PostPosted: Tue Oct 11, 2011 1:10 am Up
exhaust i'd say
206 gti 180 Wink
