Posted: Fri Oct 07, 2011 7:24 am |
Can anyone help me with a 'how to' on removing the head of my 180? Timing belt just snapped at only 38000mls!!! so i'm wanting to do a bit of the removal myself to keep the labour costs down. Cheers guys
Posted: Fri Oct 07, 2011 8:40 am |
Yeaa good luck with that!
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner | |
Posted: Fri Oct 07, 2011 8:44 am |
As above unless you know what your doing I would say leave well alone and take to someone who knows what there doing, you could end up doing more harm than good.
Posted: Fri Oct 07, 2011 8:45 am |
PugGti180 wrote: |
Timing belt just snapped at only 38000mls!!! |
Timing belts also have a time limit on them
Posted: Fri Oct 07, 2011 9:46 am |
Posted: Fri Oct 07, 2011 10:31 am |
yes haha so they do Lol that's cool then I'll just leave it to the pro's cheers for the help.
Posted: Fri Oct 07, 2011 10:40 am |
In all fairness, if it's already f****d...you can't make it much worse
Posted: Fri Oct 07, 2011 11:42 am |
Lee.
Did I ask you which program o catalog is this ?
| 2005 206 RC RED
Lot's of CNC machined customs pars. | |
Posted: Fri Oct 07, 2011 11:44 am |
Schumi wrote: |
Lee.
Did I ask you which program o catalog is this ? |
It's servicebox, online
Posted: Fri Oct 07, 2011 11:49 am |
better to check the bottom too just in case the snapped valve drops.....
80K miles or 5 yr for belt.
Posted: Fri Oct 07, 2011 12:32 pm |
Well, a nice 2nd hand engine might be better value if too much damage been done when the belt snapped.
Posted: Fri Oct 07, 2011 5:48 pm |
PugGti180 wrote: |
Can anyone help me with a 'how to' on removing the head of my 180? Timing belt just snapped at only 38000mls!!! so i'm wanting to do a bit of the removal myself to keep the labour costs down. Cheers guys |
knob!
Posted: Fri Oct 07, 2011 5:52 pm |
my previous statment may be premature....what year is your car?
Posted: Sat Oct 08, 2011 12:51 am |
I do think that just replacing the engine could work out at a similar price...
Posted: Sat Oct 08, 2011 2:53 am |
Edward wrote: |
I do think that just replacing the engine could work out at a similar price... |
Plus you'd need to get the timing belt changed on that too if it hadn't been done
