Online Now [637]:
Visitors: 635
Members: 1
Today: 41385
Total: 155005311
Forums › The Car › 206 Problems › Off side / Near side?
Go to page 1, 2, 3, 4, 5, 6  Next
PostPosted: Sat Oct 08, 2011 2:57 am Up
When Haynes refers to 'Left' side, I seem to recall that would be the driver's side (for RHD, UK vehicle) or 'Outer side' as you call it.
Anyone confirm?
PostPosted: Sat Oct 08, 2011 3:24 am Up
Left side would be passengers side n/s [nearside] in the UK
So drivers side o/s for you
PostPosted: Sat Oct 08, 2011 3:42 am Up
cheers.
banboots
PostPosted: Sat Oct 08, 2011 4:36 am Up
Left is left no matter what way you look at it!!!! roflmao....
Have a nice day!
PostPosted: Sat Oct 08, 2011 4:37 am Up
Is it left as you are sat in the car, or left as you look at it from the front Wink
PostPosted: Sat Oct 08, 2011 4:55 am Up
banboots is correct, the left hand side of the car is the left hand side of the car no matter what way you look at it Wink
PostPosted: Sat Oct 08, 2011 4:57 am Up
So if someone said to you "the battery is on the right hand side of the engine" you'd look where the ECU was? I think not
PostPosted: Sat Oct 08, 2011 5:11 am Up
Rolling On The Floor Laughing
Looking at the manual now, it says 'xxxxx of the engine compartment' when it refers to looking from the front.
Otherwise, it's as Lee said. Wink
P.S. This should be stickied. Laughing
PostPosted: Sat Oct 08, 2011 5:17 am Up
So if someone said to you "the battery is on the left hand side of the
car" you'd look where the ECU was? I think not.
PostPosted: Sat Oct 08, 2011 5:18 am Up
Mrs.V9977 would. I think so.
PostPosted: Sat Oct 08, 2011 5:19 am Up
They wouldn't say that though, as it isn't.
paul_c
PostPosted: Sat Oct 08, 2011 5:25 am Up
You'll come across loads of problems if you refer to left as right, simply because you're looking at the car (engine bay) from the front looking towards the rear!!!
For example, if I stood at the side of the engine bay looking in, I might describe the radiator as being to my left and the scuttle to my right. But If I stood the other side.....
paul_c
Gets even more confusing if you're working underneath the car looking up.....
PostPosted: Sat Oct 08, 2011 5:27 am Up
Generally speaking you refer to body panels and the inside of the car as n/s = left, o/s = right
With the engine is n/s= right, o/s = left, as you look at the engine from the opposite perspective
PostPosted: Sat Oct 08, 2011 5:29 am Up
This thread is pure genius and I demand it being stickied immediately.
Page 1 of 6
