Online Now [281]:
Visitors: 279
Bots: 2
Today: 77361
Total: 155680773
Forums › The Car › 206 Problems › ABS/ESP fault
ABS/ESP fault
Daniel206RC
PostPosted: Sat Oct 08, 2011 11:46 am Up
Hi
My RC having some issues with ABS/ESP system!
when I start the car no faults, driving away and after maybe 2-3mins the Abs light and esp light are coming on.
before the lights are coming on both are working fine, the abs kicks in and esp slow down one of the front wheels!
so my questions:
can I measure the ABS sensors?
Is it a Ohm value for the rear and front ones?
and does anyone have a electrical diagram of the circuts?
it's not in my haynes book! :/
03, RC / GTI180
03, SW XSI
PostPosted: Sat Oct 08, 2011 12:01 pm Up
Check the tyre pressures.
Check the front toothed rings on the driveshafts.
Peugeot Planet scan time
Daniel206RC
PostPosted: Sat Oct 08, 2011 2:49 pm Up
okey, i know one of the abs rings have a crack!
but the crack has been there for a year or so and the abs/esp fault came for a month ago..
so I can't measure the sensors?
03, RC / GTI180
03, SW XSI
TheGTIlad
PostPosted: Sat Oct 08, 2011 3:22 pm Up
To me this sounds like a fault coming from your hydraulic abs block. On most peugeots the abs unit controls both the abs + the esp. I suggest a peugeot planet scan to check for faults in the abs ecu(hydraulic block). I suspect the unit is at fault but i would defiantly suggest a scan with peugeot planet.
Daniel206RC
PostPosted: Sat Oct 08, 2011 3:35 pm Up
okey, Then I'll take it to peugeot.
I think it's so strange that it is coming after driving for some minutes.
03, RC / GTI180
03, SW XSI
TheGTIlad
PostPosted: Sat Oct 08, 2011 3:45 pm Up
I find this strange myself, but a simple diag check at peugeot should be able to clarify what the problem is. If i was you, i'd ask to see the print outs, and if you dont understand the print outs, ask for them to be explained a little.
Daniel206RC
PostPosted: Sat Oct 08, 2011 3:50 pm Up
found the wiring diagram:
will try to measure the sensors..
03, RC / GTI180
03, SW XSI
PostPosted: Sun Oct 09, 2011 4:13 am Up
Wasting your time looking for the fault elsewhere, replace the cracked toothed ring!
PostPosted: Sun Oct 09, 2011 4:26 am Up
The shaft ring on mine was cracked and the ABS light would come on at high speed. If you want to fix a problem you have to fix every problem. If you know something isn't right with that trigger ring then it needs to be changed. If it's cracked then it will spin on its own confusing the ABS/ESP ECU. Hence the light comes on.
Daniel206RC
PostPosted: Sun Oct 09, 2011 10:36 am Up
MrBSI: I think it's so strange, because the ring has been not as bad as Edwards but it's almost 1 tooth missing like a year and the light was starting to come on in August.
Will buy a new driveshaft and see if it fix it, but I have my doubts Razz
03, RC / GTI180
03, SW XSI
PostPosted: Sun Oct 09, 2011 10:38 am Up
How do you expect an ABS / ESP system to work correctly with a broken toothed ring?
PostPosted: Sun Oct 09, 2011 10:42 am Up
Daniel206RC
PostPosted: Sun Oct 09, 2011 11:06 am Up
Thanks lee Smile
03, RC / GTI180
03, SW XSI
