Online Now [1045]:
Visitors: 1045
Today: 43679
Total: 152690168
Forums › The Car › Request a how-to › How do I wire in this type of switch (pic in post)
devildriverxii
PostPosted: Sat Oct 08, 2011 4:22 pm Reply with quote Up
I just want to connect it to a live or ignition switch, whatever is better, and then the switch to control some chavy LED's, I'm just not sure what wire goes where Laughing
Hope the pic helps, if not I can take some.
Thanks.
2002 1.6 5dr Black Edition.
loudnproud
PostPosted: Sat Oct 08, 2011 4:27 pm Reply with quote Up
live from batt or aux on 1 side live to LED's on other, i have used my ashtray light as power for my under dash neons
devildriverxii
PostPosted: Sat Oct 08, 2011 4:41 pm Reply with quote Up
So live from the switch, and earth it elsewhere then yeh Smile
Cheers mate.
loudnproud
PostPosted: Sat Oct 08, 2011 4:46 pm Reply with quote Up
yeah my earth was a bolt under the console
banboots
PostPosted: Sat Oct 08, 2011 5:05 pm Reply with quote Up
Its actually a better idea to switch the -ve. So you would run the earth to the switch then to the lights and the +ve straight to the lights via a fuse
Have a nice day!
banboots
PostPosted: Sat Oct 08, 2011 5:10 pm Reply with quote Up
Just so thats clear the earth goes through the switch to the lights, this way less current goes through the switch. Same way you disconnect a -ve on a battery terminal first, its the best way to do it but can be done both ways.
Have a nice day!
pug206lx
PostPosted: Sat Oct 08, 2011 6:00 pm Reply with quote Up
I would run and fuse a fresh live from the battery. Only takes an extra 10 minutes.
banboots
PostPosted: Sat Oct 08, 2011 6:43 pm Reply with quote Up
Totally agree about the fresh +ve but a really good idea is to run a heavyish cable through the bulkhead and start an accessory fusebox. Its really handy for adding stuff in the future and a total doddle to do.
Have a nice day!
PostPosted: Sat Oct 08, 2011 10:59 pm Reply with quote Up
I would suggest always running the fused positive feed to the switch and then the switch to the load, and the load to earth.
If you have a problem with the accessory, you can always isolate it with the switch.
PostPosted: Sun Oct 09, 2011 1:47 am Reply with quote Up
That has an led bulb in end off switch so you will want positive on switch for it to work the led on the end, also needs the pin that comes off the side connecting to earth to make the light in the end light up Wink
PostPosted: Sun Oct 09, 2011 4:20 am Reply with quote Up
You need to brush up on your electrics if you think that is the case Wink
PostPosted: Sun Oct 09, 2011 4:28 am Reply with quote Up
The same current goes through the switch regardless of how it's wired. You need a relay if you want less current through the switch.
Why would you want to use such a big daft switch for something like LED's anyway?
austin316
PostPosted: Sun Oct 09, 2011 5:52 am Reply with quote Up
because LED's illegal if on permanantly arent they?
5 door
1.1 8v
04 reg
PostPosted: Sun Oct 09, 2011 7:47 am Reply with quote Up
No
banboots
PostPosted: Sun Oct 09, 2011 10:40 am Reply with quote Up
In my defence I had quite a few beers last night lol
Have a nice day!
  Quick Reply
Username:
Message:
Quote the last message
