Posted: Mon Oct 10, 2011 8:02 am |
hi,
the problem is that the driver's door doesn't have that 2 phase opening, now I know the thingy that does that is a small screw right at the top of the edge of the inside part of the door, but it seems the screw is just sitting there wobbling and doesn't look like it can be screwed anywhere.. any solutions?
Posted: Mon Oct 10, 2011 8:25 am |
You mean the check strap?
Posted: Mon Oct 10, 2011 8:26 am |
Ali_H wrote: |
You mean the check strap? |
Yeh sorry didn't know that's what it's called..
Posted: Mon Oct 10, 2011 8:33 am |
4 bolts to undo put a new one on, job done!
Posted: Mon Oct 10, 2011 8:35 am |
Posted: Mon Oct 10, 2011 8:42 am |
I need to do the other halfs car when I can be arsed
Thought they were cheaper than that though, good thing i'm not paying.
Posted: Mon Oct 10, 2011 8:48 am |
Ali_H wrote: |
Thought they were cheaper than that though, good thing i'm not paying. |
They are expensive arnt they!
Posted: Mon Oct 10, 2011 9:06 am |
Holy moly! that's one expensive thingy... I'll see if it can be sorted with the one currently installed and if not I'll pass on it for now.. not that much of a hassle - door is opening all the way and not having that 2 phases opening, I can live with that..
Posted: Mon Oct 10, 2011 9:15 am |
They are only 9181C8 (Right) £26.62 and 9181E1 (Left) £28.74 from the dealers.
Don't know why the difference between right and left though
Posted: Mon Oct 10, 2011 9:39 am |
macca1411 wrote: |
Don't know why the difference between right and left though |
That is wrong!
There is one part number only- 9181 C8 - check strap is reversible
The other is for a a different type of door opening
Posted: Mon Oct 10, 2011 11:26 am |
Lee wrote: |
macca1411 wrote: |
That is wrong!
The other is for a a different type of door opening |
Ah cheers Lee, was wondering what the difference was with it being "post office"
On service box where it says "2" in the column between the part number and item description, does that mean they are supplied as a pair?
Just wondering because the hinge pin has "4" in the column
Posted: Mon Oct 10, 2011 11:31 am |
Means there are 2 on the car
Posted: Mon Oct 10, 2011 11:40 am |
Lee wrote: |
Means there are 2 on the car |
I suppose that makes sense. The French aren't daft then, plus they play rugby better than us, the b******s.
