Online Now [349]:
Visitors: 347
Bots: 2
Today: 146079
Total: 155238139
Forums › The Car › 206 Problems › Clunking Noise when turning
turnerj_2001
PostPosted: Mon Oct 10, 2011 8:26 am Up
Hi Peeps,
Wonder if you couldplease help as im new to this forum.
My GF has not long got a 206 Y Reg (2K Model) and there have been some issues we have been sorting out. however recently when she turns the wheel it makes a clunking noise.
When she had her tyre's done they mentioned that the bushes are on their way out.
My Question is could that be the issue and is it quite easy to fix. I am armed with a haynes manual and alot of determination to resolve the issue. Laughing Laughing
JT
Peugeot 206 Y Reg
iainlovatt
PostPosted: Mon Oct 10, 2011 8:32 am Up
sounds like a driveshaft (CV Joint) Pain in the a**e to change!
(My Garage)
PostPosted: Mon Oct 10, 2011 9:16 am Up
Could be few things at fault, a few things to consider would be balljoint, topmount bearing, cv joint,
If the bushes your on about are the wishbone bushes I would change the wishbone as the balljoint is attached to wishbone, see what happens,
craigy00craig
PostPosted: Mon Oct 10, 2011 10:38 am Up
Does it clunk when you turn the wheel or when you are turning while driving? I had the problem when turning and it ended up being the drive shafts. Are you losing power steering at all?
Progress Threads:
eddrj
PostPosted: Mon Oct 10, 2011 10:39 am Up
i had this was the topmount bearing on mine , not too much to get it fixed.
Old car 2000/ 206 2.0 hdi.
benb
PostPosted: Mon Oct 10, 2011 11:04 am Up
could be the lower engine mount
1.1lx 2000 plate
turnerj_2001
PostPosted: Tue Oct 11, 2011 5:24 am Up
Thanks all for the comments and suggesstions that you have mentioned, in response to the Craig's
I'm not losing power steering and only occurs when turning towards full lock.
Peugeot 206 Y Reg
Ste
PostPosted: Tue Oct 11, 2011 5:34 am Up
Staff - Ste
Topmount bearings, happened to mine a while back, like a deep clunk noise going towards full lock either way, easy and cheap to fix Smile
The Cars:
turnerj_2001
PostPosted: Tue Oct 18, 2011 3:31 am Up
Hi All,
Further update from the Mrs mentioned it to her and was told it only happens intermittently.
Does that help narrow down the problem at all??????
Any help would be grateful.
Peugeot 206 Y Reg
ash125106
PostPosted: Tue Oct 18, 2011 6:17 am Up
Tbh honest its nothing to worry bout ive had this for about 18 months and mine fine just turn the radio up Razz
2006 55 Reg 206 Gti 180
Ash
ash125106
Tbh honest its nothing to worry bout ive had this for about 18 months and mines fine just turn the radio up Razz
Ash
