Latest: DanDan17
Overall: 17128
Online Now [466]:
Visitors: 465
Today: 12186
Total: 100681600
Forums › The Car › 206 Problems › main beam/full beam problem???
eggy6832
PostPosted: Mon Oct 10, 2011 12:08 pm Up
when i put my full beam on my main beams go out. just wondering if that was normal.
thanks
owner of a 206 gti
PostPosted: Mon Oct 10, 2011 12:09 pm Up
No thats not normal, sounds like it could be the relay or you may need a new comms unit.
PostPosted: Mon Oct 10, 2011 12:11 pm Up
how old is the gti? mulitlplex/preplex?
Sounds like you are non-plexed and have the wrong stalk fitted to your car.
Needs modifying or fit a relay
Non plexed unless it's had a BSI change Wink
eggy6832
PostPosted: Mon Oct 10, 2011 12:12 pm Up
oh right well its happened ever since i changed the indicator stalk as the indicator would stay on. what relay is it?
owner of a 206 gti
PostPosted: Mon Oct 10, 2011 12:13 pm Up
How the GTi came with crystals as standard so cant see it being the wrong stalk.
eggy6832
PostPosted: Mon Oct 10, 2011 12:14 pm Up
its a y reg
owner of a 206 gti
Need to read some wiring diagrams mate, circuit board is different.
PostPosted: Mon Oct 10, 2011 12:15 pm Up
thats the problem then Razz
PostPosted: Mon Oct 10, 2011 12:16 pm Up
Oh yes, Lee hits a
Got it right exactly without the OP providing any info Laughing
eggy6832
PostPosted: Mon Oct 10, 2011 12:17 pm Up
ok so which indicator stalk do ineed? as my garage provided me with this
owner of a 206 gti
PostPosted: Mon Oct 10, 2011 12:18 pm Up
Do you still have the old one? If you fit that for the time being, send me the new one and I'll fix it for you.
Still doesnt explain it Lee.
The GTi had crystals as standanrd thus having the right stalk. It wasnt mentioned until leter in the post that OP had replaced the stalk.
PostPosted: Mon Oct 10, 2011 12:19 pm Up
If you know how it works then you can spot the problem Laughing
