Posted: Mon Oct 10, 2011 12:08 pm |
when i put my full beam on my main beams go out. just wondering if that was normal.
thanks
Posted: Mon Oct 10, 2011 12:09 pm |
No thats not normal, sounds like it could be the relay or you may need a new comms unit.
Posted: Mon Oct 10, 2011 12:11 pm |
how old is the gti? mulitlplex/preplex?
Sounds like you are non-plexed and have the wrong stalk fitted to your car.
Needs modifying or fit a relay
NorthantsBen wrote: |
how old is the gti? mulitlplex/preplex? |
Non plexed unless it's had a BSI change
Posted: Mon Oct 10, 2011 12:12 pm |
oh right well its happened ever since i changed the indicator stalk as the indicator would stay on. what relay is it?
Posted: Mon Oct 10, 2011 12:13 pm |
Lee wrote: |
Needs modifying or fit a relay |
How the GTi came with crystals as standard so cant see it being the wrong stalk.
Posted: Mon Oct 10, 2011 12:14 pm |
its a y reg
Mikey2uk wrote: |
Lee wrote: |
How the GTi came with crystals as standard so cant see it being the wrong stalk. |
Need to read some wiring diagrams mate, circuit board is different.
Posted: Mon Oct 10, 2011 12:15 pm |
eggy6832 wrote: |
oh right well its happened ever since i changed the indicator stalk as the indicator would stay on. what relay is it? |
thats the problem then
Posted: Mon Oct 10, 2011 12:16 pm |
Posted: Mon Oct 10, 2011 12:17 pm |
ok so which indicator stalk do ineed? as my garage provided me with this
Posted: Mon Oct 10, 2011 12:18 pm |
Do you still have the old one? If you fit that for the time being, send me the new one and I'll fix it for you.
Lee wrote: |
Mikey2uk wrote: |
Lee wrote: |
Need to read some wiring diagrams mate, circuit board is different. |
Still doesnt explain it Lee.
The GTi had crystals as standanrd thus having the right stalk. It wasnt mentioned until leter in the post that OP had replaced the stalk.
Posted: Mon Oct 10, 2011 12:19 pm |
Mikey2uk wrote: |
Lee wrote: |
Mikey2uk wrote: |
Lee wrote: |
The GTi had crystals as standanrd thus having the right stalk. It wasnt mentioned until leter in the post that OP had replaced the stalk. |
If you know how it works then you can spot the problem
