Posted: Mon Oct 10, 2011 12:21 pm |
not got old one.so any ideas on apart number/
Posted: Mon Oct 10, 2011 12:26 pm |
You buying new? 6253 79 @ £46.28
Could just buy a cheap second hand one off eBay and I'll correct and refurb that one for you
Posted: Mon Oct 10, 2011 12:41 pm |
cheers mate also need a radio code for a kenwood kdc5027 can u help?
Posted: Mon Oct 10, 2011 12:49 pm |
3051 is the code for many factory units
Or you could try these
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds
(so that "..." disappears).
Then using your remote enter your code.
Type 2
Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Type 3
Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio
stations). "C" should display.
Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key on the remote
* Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key on the remote
* Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key on the remote
* Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key on the remote
The security is canceled and the set enters the TUNER mode!
Posted: Mon Oct 10, 2011 12:51 pm |
ok do you mean hand held remote i havent got one of those
Posted: Mon Oct 10, 2011 12:57 pm |
Lee is the Peugeot Master
Posted: Mon Oct 10, 2011 1:02 pm |
Try it on the HU then
