Online Now [329]:
Visitors: 327
Members: 1
Today: 69403
Total: 155939826
Forums › The Car › 206 Talk › 206 gti 140 clocks
206 gti 140 clocks
Forum Index › 206 Talk
rick-gti
PostPosted: Thu Oct 13, 2011 6:51 am Up
i have found a set of clocks to replace my broken set. they are the multiplex two plug type.
do the gti 140 clocks reset to match the milage on the bsi like the gti 180's
clio 197sport owner
Mattie-RS
PostPosted: Thu Oct 13, 2011 6:53 am Up
Basically which ever one is the highest mileage, be it on the clocks or the BSI
WILL become the shown mileage
PostPosted: Thu Oct 13, 2011 6:56 am Up
No 206s reset to match, don't know where you've got that information from.
Pre plexxed mileage is within the cluster whatever clocks you have it will just display that amount.
Multi plexxed 206s will update the bsi IF the mileage on the clock is higher or update the clock to the current mileage of your car.
Basically, if you get clocks on a multiplex that are higher mileage it will overwrite the current mileage. Best to just get a set thats lower.
rick-gti
PostPosted: Thu Oct 13, 2011 7:00 am Up
i have found a set for £40 which i think is good as they are selling for well over £50. but the milage is 120k and my car has only done 82k.
clio 197sport owner
rick-gti
PostPosted: Thu Oct 13, 2011 7:03 am Up
sorry the set i have found is £30 not £40
clio 197sport owner
PostPosted: Thu Oct 13, 2011 7:25 am Up
If you car is multiplex it will display as 120k and update the bsi at the same time so you won't be able to get any lower than that.
I have some gti 180 clocks on around 102k.
You can get mileage correction done though
rick-gti
PostPosted: Thu Oct 13, 2011 7:31 am Up
would i go to a peugeot garage to get the mileage corrected?
any idea what the price is?
clio 197sport owner
PostPosted: Thu Oct 13, 2011 3:13 pm Up
No Peugeot main dealer has the equipment to correct the mileage, find a set of clocks with a lower mileage then your car currently has else its gonna get expensive to put the reading right.
PostPosted: Fri Oct 14, 2011 3:40 am Up
Slip one of the guys at Peugeot some money and I bet they will change it for you, just reflash it, would take them about 20mins
PostPosted: Fri Oct 14, 2011 5:39 am Up
Places like BBA Reman can tweak mileage on clocks as long as you provide evidence to back up the claimed mileage.
