Latest: heikkisj
Overall: 17126
Online Now [53]:
Visitors: 52
Today: 14385
Total: 100228770
Forums › The Car › 206 Problems › suspension noise
suspension noise
henrymilne
PostPosted: Sat Oct 15, 2011 2:25 pm Up
Hi there, so its just my luck that i sold my car the night got the deposit and i got home and all was fine then went bk to the car to move it. And when i go full lock i hear a knocking noise. would it be the top mounts or cv joints
Henry
DMA24
PostPosted: Sat Oct 15, 2011 2:26 pm Up
I'd suggest CV joints as thats what happened to mine a few years ago. Could be either though
Owner @ Vale Automotive Flocking
www.facebook.com/ValeA...veFlocking
henrymilne
PostPosted: Sat Oct 15, 2011 2:30 pm Up
Are the expensive to get replaced
Henry
DMA24
PostPosted: Sat Oct 15, 2011 2:31 pm Up
I picked up some 2nd hand shafts for around £15 each, did the job
DMA24
PostPosted: Sat Oct 15, 2011 2:33 pm Up
Just sent you a PM mate
Rob2859
PostPosted: Sat Oct 15, 2011 5:50 pm Up
CV joints, top mounts or possibly wishbone bottom joints.
PostPosted: Sun Oct 16, 2011 1:19 am Up
Don't put the steering on full lock...
