Online Now [347]:
Visitors: 346
Today: 113534
Total: 156220151
Forums › The Car › 206 Problems › Indicator randomly coming on ?
KyleHaich
PostPosted: Sun Oct 16, 2011 7:11 pm Up
As title, when I'm driving the right indicator comes on completely randomly, also does it occasionally when first starting the car in the morning etc.
If I try to indicate left while it's indicating right - both flash at the same time as if I have my hazards on, anyone have any ideas?
shell-vt
PostPosted: Mon Oct 17, 2011 1:18 am Up
Trade Rating: +46
hope this helps, our old ph1 gti used to do it and it turned out to-be the stalk..
york 16,3
PostPosted: Mon Oct 17, 2011 1:33 am Up
Plexed or pre plexed might help.
Take it you haven't done a search for indicator problems before starting the thread.
KyleHaich
PostPosted: Mon Oct 17, 2011 8:56 am Up
pre plexed done a search but couldn't see any problems the same as mine?
New - Pearl Blue Golf Mk4 Match 1.4
Old - Silver 206 LX 1.1
PostPosted: Mon Oct 17, 2011 8:58 am Up
Clean out OR change the stalk would be a good starting point.
Most likely find plenty of metal swarf inside shorting the stalk contacts.
If your really unlucky it will be the BSI relays & they aint easy to replace.
KyleHaich
PostPosted: Mon Oct 17, 2011 9:00 am Up
How do you remove the stalk, any how to's just had a quick look on maintenance how to's and can't see one?
PostPosted: Mon Oct 17, 2011 9:07 am Up
Undo the 2 x torx 20 screws to remove the steering coloumn trim, bottom trim falls away & top trim lifts of, then undo the 2 x torx 10 screws holding the stalk, then unclip / slide the stalk out & unplug it.
spud_owen
PostPosted: Mon Oct 17, 2011 9:08 am Up
dont remove the stalk yet, first thing to do its take to steering wheel cowlin off, then spary WD40 at the stalk where it is hinged from, work it in by moving the stalk in all direction and then spary abit more for good luck! this should sort it, if it doesnt the stalk has had it and you need a new one!
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
KyleHaich
PostPosted: Mon Oct 17, 2011 9:09 am Up
Nice one will give it a try, thanks !
