Latest: ArtistKS
Overall: 17145
Online Now [71]:
Visitors: 70
Today: 26319
Total: 115899122
Forums › The Car › 206 Problems › 206 GTi 180 Not starting
LiamGTi180
PostPosted: Thu Oct 20, 2011 12:46 pm Up
Ive been having a problem with my car for a while ago. I go to start the car and then it sounds like its struggling to turn over. Then all of the doors luck. Normally second time round it starts fine.
Anyway I come to start the car tonight and the automatic headlights had switched themselves off. They turned back on fine. I still have the original problem of the door locking but it wont start at all now. Any ideas what the cause could be. Also the clocks occasionally reset after trying to start.
Andy180
PostPosted: Thu Oct 20, 2011 12:51 pm Up
Battery might be on the way out.
GTI 180
PostPosted: Thu Oct 20, 2011 12:53 pm Up
Check the condition of the battery and the power and earth straps
LiamGTi180
PostPosted: Thu Oct 20, 2011 1:01 pm Up
Ok will do. would that cause the doors to lock and other problems? Sound likely tho. Also alarm has been going off randomly too. Thanks for your help
sri16v
PostPosted: Thu Oct 20, 2011 1:37 pm Up
Sounds like battery especially now the temperatures are dropping. Mine used to struggle to start and the doors would lock and I would also get airbag faults, changed battery and has never happened again
2004 GTi 180
jordey-hdi
PostPosted: Thu Oct 20, 2011 1:56 pm Up
Defiantly sounds like the battery is dying or dead, the doors will lock on their own due to the battery being dead, same with the alarm.
Get the battery and charging system checked;)
You'll want a decent battery for the winter months
...jordey
Horsepower wins arguments.......torque wins races
PostPosted: Thu Oct 20, 2011 2:08 pm Up
Needs a new battery, the original factory fitted Varta one will be worn out.
stuy180
PostPosted: Thu Oct 20, 2011 2:30 pm Up
Another one here to recommend the battery! Very Happy
Brian
PostPosted: Thu Oct 20, 2011 2:35 pm Up
Trade Rating: +31
tip: switch a known working battery in there to establish that it's definitely that before shelling out £60+ on a decent battery.
