Online Now [399]:
Visitors: 398
Today: 123928
Total: 154681270
Forums › The Car › 206 Problems › Air con problem
Air con problem
eggy6832
PostPosted: Sat Oct 22, 2011 9:37 am Up
I have a problem with my aircon I can't control the temperature up or down! I never used to be able to turn aircon off without changing fuse.
But I have since replaced blower motor but can't control temperature it just stays the same if I put it up or down and would like together this sorted for those cold mornings on way to work Shocked
owner of a 206 gti
PostPosted: Sat Oct 22, 2011 10:28 am Up
GTI will have climate control, did you fit the correct blower motor for the climate control system?
PostPosted: Sat Oct 22, 2011 11:42 am Up
Sounds like it could be the control unit (i.e. the screen and buttons) that is at fault.
BBA Reman can fix them. They will also test it to see if it actually needs fixing.
eggy6832
PostPosted: Sun Oct 23, 2011 7:04 am Up
Yeh well originally I could turn air con off but could control temp now I can turn off but not temp so it's unlikely to be the buttons is it?
owner of a 206 gti
eggy6832
PostPosted: Sun Oct 23, 2011 7:11 am Up
That should of said couldnt
owner of a 206 gti
