Latest: elelectricistadeMateo
Overall: 17127
Online Now [45]:
Visitors: 44
Today: 5389
Total: 100403614
Forums › The Car › 206 Problems › So where does this wire plug into?
Cal91
PostPosted: Thu Oct 27, 2011 10:02 am Up
This is my first post to go easy! Smile
After digging out the 206 (been sat in a garage for a few years), I've given it a clean up and got it started!
Good little cars, not been started for 3 years or driven for 4 and it started 3rd turn of the engine. I never used any quick start spray or anything... it didn't even need jump leads because the battery had been disconnected.
But anyway, after cleaning the engine bay I noticed this random socket not plugged into anything.
All lights are working, (the left sidelight is pretty dim, but its definitely working).
This is on the passenger side, next to the battery.
Any ideas?
Car: Peugeot 206 1.1L Look 2002
Antknee
PostPosted: Thu Oct 27, 2011 10:06 am Up
indicator?
PostPosted: Thu Oct 27, 2011 10:08 am Up
Was going to say possibly H7 connections but it looks the wrong size totally for it.
Cal91
PostPosted: Thu Oct 27, 2011 10:10 am Up
I thought that, but the indicator is working and the wire isn't long enough to stretch across.
Do you see the hole punched out in the metal just under the socket? The rectangular hole?
The socket happens to be exactly the same size as that, and it sort of sits into the groove.
I was wondering if something is meant to be poking through that hole.
Possibly something to do with ABS.
PostPosted: Thu Oct 27, 2011 10:12 am Up
See if you can find some numbers on the wires somewhere.
Antknee
PostPosted: Thu Oct 27, 2011 10:17 am Up
OH! fog lights?! some models have the wiring but not the actual light units on the bumper
Cal91
PostPosted: Thu Oct 27, 2011 10:19 am Up
There is no numbers on the wire itself.
The socket has a number on it, but I think its a part number.
It reads... >PBTP QF 30<
After looking about, its the exact same socket that is connected to the indicator.
The car has no fog lights, so could be that!
But wouldn't it be strapped up? or at least have a cover over the socket!
Antknee
PostPosted: Thu Oct 27, 2011 10:24 am Up
remember its peugeot you're talking about here Laughing
Cal91
PostPosted: Thu Oct 27, 2011 10:26 am Up
Laughing The car isn't actually mine, its my mums. I drive a Vauxhall Astra... a bit different to the 206, I must say!
This.
Rob2859
PostPosted: Thu Oct 27, 2011 1:16 pm Up
Wrong. I stumbled across this wire today and I have fogs. Its the same figment as the indicator. I also have a H4 plug under my headlamp Very Happy
PostPosted: Thu Oct 27, 2011 1:26 pm Up
Ooo, ooo, can i have a wild stab in the dark too??? Erm... Autolights.
Yeah, thats it.
PostPosted: Thu Oct 27, 2011 1:43 pm Up
The sidelight uses a plug like that.
PostPosted: Thu Oct 27, 2011 3:17 pm Up
Yeah, thats it.
Autolights only add's a plug for the rain / light sensor inside the car, doesnt add anything under the bonnet.
