Posted: Fri Oct 28, 2011 3:27 am |
Hi everyone. The buttons on the remote key fob were worn out so I bought a new shell off ebay. I swapped the blade and circuit board over and the new key locks & unlocks the car but there must be a problem with the immobiliser as the car turns over but will not start. The spare key still starts the car as normal.
Any ideas ?
| 206 LX 2001 1.1 3 door hatch in Aluminium Silver | |
Posted: Fri Oct 28, 2011 4:31 am |
hi, when you swapped the board over, did you swap the black chip too? if not make sure you can find it, as you won't be able to use the plip without it.
Posted: Fri Oct 28, 2011 4:38 am |
davecuk wrote: |
hi, when you swapped the board over, did you swap the black chip too? if not make sure you can find it, as you won't be able to use the plip without it. |
You need the transponder in the new flip key, just a small black chip transfered to then at should be ok
| 206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955) | |
Posted: Fri Oct 28, 2011 4:44 am |
When you open the fob, the transponder chip is in the side that holds the key blade, small & grey, remove with care.
Posted: Fri Oct 28, 2011 4:45 am |
scotty57 wrote: |
Any ideas ? |
Transponder chip is still inside your old keyfob.
Posted: Fri Oct 28, 2011 6:43 am |
Posted: Fri Oct 28, 2011 8:31 am |
of course - what a plonker !!! thanks guys.
