Online Now [387]:
Visitors: 386
Today: 129519
Total: 156235511
Forums › The Car › 206 Problems › Drove through water, car stalled now won't start
Mkajuma
PostPosted: Sat Oct 29, 2011 8:17 am Up
pug206lx wrote:
Did you crank it from the crankshaft pulley or did you spin it on the starter? Any knocking noises? You'll soon know when you've changed the plugs.
Starter. Put the key in and cranked it repeatedly, water shot out of the spark plug holes. Kept cranking until none was coming out. Then put in some used but ok plugs I picked from a mate, stuck the new filter in and the car started on the 3rd or 4th try.....sputtered a bit, then ran not too badly, revved it and let it idle intermittently for about 5-10 min then turned it off and stuck in the new plugs. Started on the first kick, good as new. WHOOP WHOOP.
All this was last night been running as normal all day today.....f*****g ecstatic no engine damage thanks heaps guys....you really should charge for your advice LOL
Click Here for my WIP
2001 1.4Lx
Custom Dual Exhaust
Custom Bodykit
Banging stereo Smile
ExoVyper
PostPosted: Sat Oct 29, 2011 9:10 am Up
who said i didn't charge for my advice? :L
that'll be two cinnamon danish whirls please Smile
mjsroofing
PostPosted: Sat Oct 29, 2011 3:08 pm Up
i've done this a couple of times and its not as good as it sounds, the chances is that the con rod is bent slightly and after a few miles maybe a 100 or two miles it'll snap, and poof goes the engine, if i was you i'd get rid of it before it blows up.
the first signs i seen on the two i have done was it useing more fuel and slightly less power, think it was about 2 months before it went on the 406 and about 2 days on the escort van, and both sounded lovely after i got them going, i was gutted twice. never again.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
deanparkr
PostPosted: Sat Oct 29, 2011 6:00 pm Up
Whats a con rod?
2002 1.4LX
no_offences
PostPosted: Sat Oct 29, 2011 6:01 pm Up
had a similiar situation myself, dried the engine out got it running again but it was beyond repair just hope for the best
Signature removed due to size
no_offences
PostPosted: Sat Oct 29, 2011 6:02 pm Up
i had less than a week then bang lol
Rob2859
PostPosted: Sat Oct 29, 2011 6:03 pm Up
I drove through a very deep ford once. The wave came to the bottom of my windscreen. It cut out on the way out but started after a while. Changed the plugs and filter and it was fine for a week apart from a slight knocking noise when cold. It threw a rod a week later. two massive holes ether side of one cylinder. When I got the engine out the sump was full of water too.
PostPosted: Sat Oct 29, 2011 9:17 pm Up
in what?
ExoVyper
PostPosted: Sun Oct 30, 2011 12:21 am Up
deanparkr wrote:
Whats a con rod?
a con rod or Connecting rod is the rod that links your piston head to the crankshaft
PostPosted: Sun Oct 30, 2011 8:33 am Up
did you post the pic on info before?
i do remember someone did something similar before....think is a 1.1 and it drove through a pond and cut out, engine blown after a month or so Laughing
longeatonlad
PostPosted: Sun Oct 30, 2011 11:04 am Up
i picked some posh dude up that drove his mini one through a ford, got stuck then tried cranking it over in the middle. that had locked, and there was a puddle of oil underneath...
as it was his own fault i even threw the winch cable in so he could attatch it himself, i dont get paid enough to get wet Smile
206 gti 180 Wink
Rob2859
PostPosted: Sun Oct 30, 2011 2:03 pm Up
In a ford E5GDM. As in a shallow river that runs across a road. although it was not very shallow at the time.
Look familiar? Very Happy You can see straight through the other side.
mjsroofing
PostPosted: Sun Oct 30, 2011 3:33 pm Up
dont drive it , just get rid of it.
Mark
ronnie
PostPosted: Sun Oct 30, 2011 3:35 pm Up
I've noticed the air filter hose goes under the car and up the inner wing.
Sucking up water will destroy your engine as it can't be compressed and the engine has hydauliced.....piston tries to squash the water but it can't and it then finds a weak link.....usually the rod bends or it is thrown out thro the side of the block.
A neigbour drove his V12 Aston thro a flooded bit of road.......AA picked him up and I noticed his car on an auction site sometime later as a write -off because of the engine damage
I feel the air filter hose is a poor design as it is so low down
I feel your pain
Ronnie
ronnie
PostPosted: Sun Oct 30, 2011 3:39 pm Up
Gutted
Page 2 of 3
