Latest: sparrowdclxvi
Overall: 17139
Online Now [157]:
Visitors: 156
Today: 16426
Total: 113464752
Forums › The Car › 206 Talk › Fitting injectors
Fitting injectors
Gaz360
PostPosted: Sun Oct 30, 2011 4:46 pm Up
I am just about to change a fuel rail and the injectors.
Is there anything I should be aware of or is it just a simple case of taking them off and putting the new ones in??
PostPosted: Sun Oct 30, 2011 4:47 pm Up
Just watch for fuel p**sing out.
Make sure you've cleaned up before cranking, and wait at least 10 mins inbetween fitting and cranking.
Also prime the system.
Gaz360
PostPosted: Sun Oct 30, 2011 5:01 pm Up
Ok cheers. What do you mean by priming the system?
PostPosted: Sun Oct 30, 2011 5:02 pm Up
Get the air out of it.
Little blue bleed cap on the rail
Gaz360
PostPosted: Sun Oct 30, 2011 5:24 pm Up
ok. So take injectors of... clean up the fuel... wait bout 10mins.... (and turn the blue screw to let the air out)... then put the new ones in. Doest that sound about right?
Gaz360
PostPosted: Sun Oct 30, 2011 5:25 pm Up
"sorry DOES that sound about right?" i ment
PostPosted: Sun Oct 30, 2011 5:27 pm Up
Remove the injectors/fuel rail
Block up the fuel line with toilet roll
Fit the new injectors/fuel rail
Clean up any spilled fuel and wait 10 mins.
Open the blue screw, turn the ignition on and as soon as fuel comes out of it, tighten it up.
Happy days.
Gaz360
PostPosted: Sun Oct 30, 2011 5:48 pm Up
Ok thanks for that. much apriciated Smile
PostPosted: Mon Oct 31, 2011 2:18 am Up
I've completely drained the rail on mine and just started it as normal. No need to risk fuel squirting out of the schrader valve.
sri16v
PostPosted: Wed Nov 02, 2011 2:57 pm Up
agree with this, no need to bleed the system on any petrol car Ive come across, im sure there are exceptions though
2004 GTi 180
PostPosted: Wed Nov 02, 2011 3:14 pm Up
Piece of mind rather than a necessity
Gaz360
PostPosted: Fri Nov 04, 2011 4:54 pm Up
Thanks for the input. All went ok an cars running great now thanks. only thing i should bear in mind next time is not to put my head over the valve when checking if its primed. face full of fuel lol Very Happy
