Forums › The Car › 206 Problems › which tappets for a 2.0ltr ??? |
Posted: Tue Nov 01, 2011 11:59 am |
A little tappet noise on start up from what appears to be only one tappet.
Have been told that other tappets are a better choice when replacing them
Anyone know which ones to use from 1.8 1.6 or 2.2 peugeot engines?
Has anyone replaced their tappets?
Easy job?
Ronnie
Posted: Tue Nov 01, 2011 12:43 pm |
Just get new ones for the EW10. Once upon a time they suggested using them from the EW7 but that's not necessary now.
It's basically a cambelt job plus the whole belt cover, cam pulleys and cams need to come off.
Posted: Tue Nov 01, 2011 2:42 pm |
Thanks for that Edward
Seems a big job for a little ticking noise when cold (turn the radio up or cure?)
Why were tappets used from the 307 rngine ? Was this an improvement over standard
Anyone have photos of the head with the cam cover off to see what's involved
Ronnie
Posted: Tue Nov 01, 2011 3:05 pm |
Put it this way, it's not really a DIY job. Not one for the inexperienced.
