Latest: heikkisj
Overall: 17126
Online Now [127]:
Visitors: 126
Today: 19715
Total: 100352678
Forums › The Car › 206 Problems › squealing sound when coasting only
thickid
PostPosted: Tue Nov 01, 2011 12:18 pm Up
I have a 2000 W reg 1.4lx 206. In the last few weeks I have noticed it making a squealing noise when coasting along at low speed (10-20mph). Obviously at that speed it is only noticeable when I am in fairly slow/heavy traffic. It does seem quite loud though. It sounds more like a rotary noise as opposed to a rubbing noise but this is just my guess on it.
Can anyone give me any (sensible) pointers on what it might be and if they think it would be expensive to fix? Could a reasonably competent person fix it at home with basic motoring tools?
I would be really grateful for any advice before going to a garage Very Happy
Photographer - www.flickr.com/photos/...isengland/
PostPosted: Tue Nov 01, 2011 12:29 pm Up
Loose belt?
thickid
PostPosted: Tue Nov 01, 2011 12:35 pm Up
would that need replacing or is it something that can be re tensioned? could a home mechanic do that?
kit325
PostPosted: Tue Nov 01, 2011 1:47 pm Up
Could be the drive belt tensioner bearing or just the drive belt. Is this only happened when the engine is still warm? any improvement after the engine properly warm up? When was the last time u change your drive belt?
If just the belt need changing then just a maximum 15 minutes (2 spanner rating) job and will be under a tenner for the belt. If the bearing need changing it can cost u from 40 maybe up to 90 pounds if the tensioner bearing is self adjusted (u can see spring like attactment near the bearing).
If the noise is not too much, just turn on your music and ignore it! Smile
kit
Ash
PostPosted: Wed Nov 02, 2011 1:28 pm Up
Not for the bearing. Mine use to squeak and it wasn't that much to change.
Does the sound change with Engine Revs or Speed? If its Engine Revs, its probably timing belt or more likely, the aux belt (and the relevant surrounding parts)..
With speed, suspension, wheel hub, bearing, so on..
