Online Now [1184]:
Visitors: 1183
Today: 260433
Total: 151383472
Forums › The Car › 206 Problems › Do i take this out???
LiamGTi180
PostPosted: Thu Nov 03, 2011 5:51 am Up
What do i do with everything below the red line when fitting an induction kit? Its in the way of the cold air feed. Also it seems pretty pointless just sat there disconnected. thanks
LiamGTi180
PostPosted: Thu Nov 03, 2011 5:52 am Up
I have already removed the airbox etc just wondering what i do with the remaining.
Mrs_Howey
PostPosted: Thu Nov 03, 2011 5:54 am Up
You can remove it, it's not very hard to do Smile part 5 goes behind the wing and just pulls out and iirc part 7 is just a bolt or 2 to remove. Weight saving Razz
Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre Very Happy
LiamGTi180
PostPosted: Thu Nov 03, 2011 6:16 am Up
so it what is it lol. sorry Ive never seen anything like it before. Thanks for your help
PostPosted: Thu Nov 03, 2011 6:18 am Up
It's the secondary air pump, normally throws up a fault code in the ECU when you remove it.
LiamGTi180
PostPosted: Thu Nov 03, 2011 6:27 am Up
so id it worth removing it then? just hangs at the moment?
LiamGTi180
PostPosted: Thu Nov 03, 2011 7:29 am Up
so what can i remove without throwing up faults?
jimjam19927
PostPosted: Thu Nov 03, 2011 7:56 am Up
Just take the air box out and leave the rest there.
Member: 685
I Over Use Smilies Razz
